Hi guys, been a long time since I posted here. I am moving very soon, and I have a chance to put an IB sub into a utility room. The utility room contains hot water tank, gas furnace and HRV. Would putting an IB in there with four 15" adire tempests be a good idea? I have some old drivers lying around.
IB Sub with Build Volume in Utility Closet
I loved my IB subs when I had them. I think the rule of thumb is the rear volume needs to be somewhere around 10 x VAS or more to behave as IB. Mine were a little tight, but still better behaved than any reasonably sized box. So, if the utility room is big enough, go for it. Even if you've only got the room for two in IB possibly augmented with box subs do it. I just wish I lived where it was possible to have an IB sub.- Bottom
I have (4) 18s in my floor under my couch in an IB setup, it's simply violent. I love it. We don't even really turn them up that loud, but it's pretty incredible. We were watching a movie the other day where the inaudible low frequency effects were causing a very subtle vibration/rumble (I believe it was a scene with a train). Felt like the couch was on the train. It was crazy.
Anyways, definitely do it! We are flat to 5hz and it's simply unworldly.- Bottom
I'm running two (front wall with 4x15 and rear riser with 2x15) and am only pushing flat to 16Hz, but even at only ~5x VAS it does what it should... it's just there subtly, articulate and beautifully blended and not obvious and then BOOM the room shakes and you jump and... back to the simple sound. As long as the location is workable, I think you'll do fine. I could go lower if I went less flat and spent a bit more time tuning the EQ (there IS a null that's getting a little more power to it than it probably should...)
I tore out a (horrible and dangerous) ventless gas fireplace in the front wall, and the fireplace bump-out is the box volumethere (slightly widened so I could put a 115" wide screen on the wall.) Use what you have.
CdiVine Sound - my DIY speaker designs at diVine Audio- Bottom
Bass may travel thru a hot air system's duct work. If you're trying to isolate the bass from the rest of the house it may not be a good idea. If you have an existing sub you could try it first.- Bottom
kevinm, would you have any pics or a build log of that? It sounds very interesting. Are they up-facing or what? I might build a raised platform for a friends couch/HT room so looking for ideas.I have (4) 18s in my floor under my couch in an IB setup, it's simply violent. I love it. We don't even really turn them up that loud, but it's pretty incredible. We were watching a movie the other day where the inaudible low frequency effects were causing a very subtle vibration/rumble (I believe it was a scene with a train). Felt like the couch was on the train. It was crazy.
David- Bottom
Good point. I was wondering if having a furnace behind the sub would cause rattles. Lot's of flat tin panels on a furnace/plenum that might get excited with low frequencies but I've not built an IB so I have NO idea how much backwave they produce.- Bottom
How are the woofers positioned on your riser cjd? Up? Front?I'm running two (front wall with 4x15 and rear riser with 2x15) and am only pushing flat to 16Hz, but even at only ~5x VAS it does what it should... it's just there subtly, articulate and beautifully blended and not obvious and then BOOM the room shakes and you jump and... back to the simple sound. As long as the location is workable, I think you'll do fine. I could go lower if I went less flat and spent a bit more time tuning the EQ (there IS a null that's getting a little more power to it than it probably should...)
C- Bottom
More about the whole project here: http://www.divine-audio.com/home-theater-mkii/
I really need to add some updates, I have most of the walls treated now, and will be working on some cabinetry and finishing trim soon too.diVine Sound - my DIY speaker designs at diVine Audio- Bottom
Sure thing. Here you go.
DIY (Do it yourself): Cabinetry, speakers, subwoofers, crossovers, measurements. Jon and Thomas have probably designed and built as many speakers as any non-professionals. Who are we kidding? They are pros, they just don't do it for a living. This has got to be one of the most advanced places on the net to talk speaker building, period.- Bottom
by Club1820Hello everyone. Would appreciate some help. I recently purchased a M&K Sub VX-860SF 250 Watts used on Audiogon. The sub was originally purchased in Nov 05' so its pretty much new. I looks beautiful (Cherry Veneer) and does in fact look brand new. I hooked it up last night to my 1052 and was...-
Channel: Club Rotel
by AwArEnEsSI have listened to JL audio E110 at an audio shop, in another city.The reason why I want a sub is mostly feeling the sound at my body,gut especially
, also hearing the lower frequencies which my speakers(or any other speaker) can't give.
When we arrived,I asked the sales person if we...-
Channel: Audio Hideout
by snmhansonAs I mentioned in a couple other posts, I just finished up my first DIY speaker project which was a sealed sub. It is ~3 cf and uses a Dayton MKIII 15" driver with a Bash 500 watt amp. As most people seem to do, once I had it put together, but before finishing it, I installed the amp and driver...-
Channel: Mission Possible DIY
by photomanToday, I've gotten around to setting up my 1068 for HT correctly. I went out a got a SPL meter (radio shack model). So, I go though the motions measuring distances, and using 80db as the sound level to achieve from my listening position. I did the fronts, center and rears, but I got to the sub, I wasn't...-
Channel: Club Rotel
by AwArEnEsSThis will be my first sub and I have a question: Is there a volume knob on subwoofers?If yes, while changing volume levels of a/v receiver and subwoofer, how can I know if the subwoofer can handle that level? Or is increasing receiver's volume level does not affect subwoofer's toleration?-
- Loading...
- No more items.
