This will be my first sub and I have a question: Is there a volume knob on subwoofers?If yes, while changing volume levels of a/v receiver and subwoofer, how can I know if the subwoofer can handle that level? Or is increasing receiver's volume level does not affect subwoofer's toleration?
Subwoofer volume level and receiver volume level : A sub newbie question
Most subs have a volume knob. Best to use some sort of SPL meter to set your volume, but if you don't have one, you can try something like 1/3 to 1/2 on the sub volume setting and then run the test tones on the receiver. If it's a recent model, it will set levels for each channel, including the sub, automatically. After that, you can use a measurement device (best practice) or your ears (better than nothing) to set sub volume to taste (either with the volume knob on the sub or with the level trim settings in the AVR). Many people like to run their subs a bit "hot" (several dB above the automatic setting on the AVR). As long as your sub volume knob is set to 1/2 or lower, I doubt you would damage it with your AVR settings--unless you plan to listen to your movies at near full volume on your AVR (something to be strongly discouraged if you wish to A) not damage your hearing and B) prevent your gear from dying).- Bottom
I agree with Ovation on this one. Set your sub's volume to 1/2 , walk away, and use your AVR to do final adjustments to the sub's volume. As well, most phone's now have SPL apps that you can use to set volume levels, both with the main speakers and the sub.
I personally find it better to adjust the sub by ear and while listening to music (Preferably something simple like jazz). The sub should blend in with your mains (Not dominate) and compliment them by providing nice, low end bass. Also, unless you have a specific reason to do otherwise....... via the AVR, set all your speakers to 'small' and use the THX benchmark and set your sub crossover to 80hz. Normally, this crossover is set via the AVR. This will free up piles of power for your AVR to perform it's best.Dan Madden :T- Bottom
Thanks for your answer.
I bought a subwoofer a few days ago,and I left master level on subwoofer at 0(I think it is what you call "1/2").Then I set the ch level of subwoofer to +2db on receiver.X.over frequency(crossover?)setting on receiver is set to 80hz.
My problem is,the metal part of subwoofer which has master level,crossover freq,phase etc. quickly gets hot.Just 10 minutes of listening to songs make that metal part warm and after about 1 hour,that metal part gets very hot,sometimes even it's hard to touch it.I hope I don't have to lower the settings (master level and ch level) because it can much lower the impact of subwoofer.Last edited by AwArEnEsS; 25 April 2015, 14:59 Saturday.The universe arises from definitionless awareness.- Bottom
The fact that the metal amp section of the sub gets that hot (too hot to touch!) is concerning. Two quick questions:Thanks for your answer.
1. Are you sending the low frequency signal to the sub using an RCA patch cord from the AVR ?
2. Do you have the crossover setting on the sub set to 'Bypass' or 'Off' ? This is important since the AVR is doing the low frequency crossover work and only sending 80hz and lower signals to the sub.Dan Madden :T- Bottom
Thanks for your answers.
Yes,it is set to off.2. Do you have the crossover setting on the sub set to 'Bypass' or 'Off' ? This is important since the AVR is doing the low frequency crossover work and only sending 80hz and lower signals to the sub.
I think 0 setting on my sub doesn't mean max level,it's in the middle,in the middle between min and max.Ovation wrote:
The 0 setting may represent full volume on some subs. Double check on yours. Some amps run hot. Is the sound distorted? .
The sound is never distorted.
Thanks for recommendation.I never increase the sub's master level more than "0".Also, best to lower the sub's output and raise the level settings on the AVR, rather than the reverse.
Also today I noticed that,metal knobs on the metal part of sub's amplifier gets too hot,more than that metal part itself.The universe arises from definitionless awareness.- Bottom
by RaelI've owned my 1068 processor for a couple of years now and never had any problems until recently. All of a sudden, the volume knob has a mind of its own. When I go to turn it, it will suddenly jump from 58 down to 35 or even all the way to max! It doesn't matter if I turn it up or down, I never know...-
Channel: Club Rotel
by alkalayHey rotelian mates,
Has any of you experienced a loose volume knob on a 1066, 1068, 1098 or any other Rotel's pre, integrated or receiver?
My 1068 exhibits this looseness when turning the knob to one direction and then to the opposite one. First I thought it was normal...-
Channel: Club Rotel
06 February 2005, 14:08 Sunday -
by Club1820Does anyone know if the volume knob on the 1068 is supposed to be illuminated? I noticed that there is a blue ring around the knob and thought maybe it was supposed to light up?
thanks.-
Channel: Club Rotel
by QuantronicsI've been a long time Rotel user w/ a 1098 processor and 1095 amp. I upgrade my 2.x firmware to the latest firmware. I also upgrade the EPROM using the directions on Rotel's website. I used all 4 EPROM upgrade 1, 2, 3 and 4 in that order. I then upgraded to the latest 4.x software. Everything went...-
Channel: Club Rotel
by maveIs there a blue light around the volume knob ? There seems to be on various pictures, but it's not working on mine.........-
Channel: Club Rotel
- Loading...
- No more items.
