I was watching a movie tonight and the center channel began crackling and popping. I thought my center speaker had gone south, but testing revealed the center channel on the amp died. I use a separate stereo amp, so I have two spare channels available. Moved the preout and speaker-level connections to the front right channel and ran test tones. When it cycled to the channel, same crackling and popping. Now, the front right channel's dead too. Moved the preout and speaker-level connections to the front left channel on the 1075 and it is intact. So I'm temporarily relying on that channel to keep my system running, but any clues as to what might've happened? Blown fuses? Help please!
Center and front right channels on 1075 dead
by TEKHi folks
It seems like my THULE Space PA350B is starting to say "goodbye" as I'm getting crackling noices from one channel.
The PA350B was used to drive side, back and center channel (5 channels). Now I have disconnected the side speakers as one channel was making a noise....-
Channel: Class D Projects
by Ray F.The right front channel on my Rotel RMB-1095 amplifier stopped working about a week ago. I thought I had noticed an electrical component burning smell the day before, but could not locate the source. When I took the cover off, I found a big pile of cat hair inside. I suspect this caused an electrical...-
Channel: Club Rotel
by JPHey guys, so this has happened in the past. ( I drop an RCA cable and it falls on the positive/negative speaker terminals, I curse myself and then replace the fuse kinda thing) This time though, no such easy resolution. I come back from vacation just 2 days ago. The power had gone out a few days earlier,...-
Channel: Club Rotel
Hi GUys,
I am looking at 2 models of the Rotel 2 channel amps and trying to decide which on to get, either the RB-991 or the RB-1080.
RB-991 =
Total Harmonic Distortion (20-20,000 Hz, 8 ohms): - less than 0.03 percent
Continuous Power Output (20-20,000...-
Channel: Club Rotel
by kcsunMy home theatre setup uses 803di as left and right and an HTM2Di as centre. My ongoing issue is that of intelligibility of speech. I do realise that actors do not speak "proper" any more and do not always face directly to the microphone when talking. (this is why animated movies are usually...-
Channel: Club B & W Speakers
- Loading...
- No more items.
