I have hooked up my HDTV receiver to my 1068 with an optical-digital audio cable (took the first one back because I thought the cable was bad) so I can get a better movie like atmosphere with cable shows.
The sound is coming out at a lower level and sounds smeared at times.
On some channels the ancillary or background noise or sound effects are at the correct volume but the voices are still at a very low level. I have the volume turned up to 87 on the unit and still the voices are at a low level.
I have the input set to the correct optical output. I also only have 2 speakers and a sub now so I have the speakers set accordingly in the setup area.
Can any of you rotel experts lend a hand. I thank you in advance.
