denon 2200 sub output problems/questions
  • rcchap
    • Jan 2004
    • 49
    i recently purchased a denon 2200 dvd player and i'm having some issues with signals to my sub. only when using 5.1 direct from denon to reciever. i have to turn bass enhancer on in the audio set up in order to get any signals to my sub. as i understand it the bass enhancer is for sending signals to the sub when playing two chanel audio signals. i have to have bass enhancer on whether playing two channel or multi channel sacd in order to get any signal. when i turn the 'filter' setting to off which is recomended for dts play back and suposedly increases the subwoofer volume by 15 db when listening to sacd i get nothing unless i have the bass enhancer set to on. is there something that i don't understand about the audio set up or is something wrong?
    thanks for your help.
    chris
  • Hoosier Audio Nut
    SACD and DVD-A have subwoofer levels approx 10 db below regular DVD's. So what you want to do is use the sub adjustment in the 2200's setup that increases the sub level by +10db. Leave the Filter function as it came out of the box and do not use the bass enhancer.
    The +10 db change will only affect the analog outputs. What I recommend (and what I do with my 2200) is to use the 5.1 analog outputs for SACD and DVD-A and use the digital output for eveything else. This will make a big improvement in your sound...
    HAN
    HAN
      Twin Moderator Emeritus
      • 16706
      This could be a couple other things as well....
      One- Have you made sure that the sub is listed as "ON" in the DVD player? If it is set to off it will re-direct the bass to the mains. Then (I assume) you're setting your receiver to pull bass from the main channels and re-direct it to your sub with the "bass enhancer" option.
      Two- Not all SACDS and DVD-A's have information recorded in the LFE channel. As such, depending on your discs, there might not be any info there to send to the sub.
      Need a new display? Questions about new display technologies? Visit RPTVs, plasmas, and other monitors @ HTguide
      • capslock
        dual bass arrays / active traps?
        by capslock
        I read up on bass absorbing panels, membrane absorbers and Helmholtz resonators. All very nice, but with a lowish SAF. How about active traps?
        1. classic DBA (delay between arrays)
        The one thing I came accross is a DBA (dual bass array), as it is known in German discussion...
        15 August 2006, 02:23 Tuesday
      • moonlightdrive21
        For those of you using a sub with 802D's...
        by moonlightdrive21
        Hey guys:
        Would you mind please answering the questions below, which I think would be helpful to many forum members?:
        1) Considering that the 802D's are amazing full range speakers, what made you decide to integrate a sub into the mix?
        2) Do you only use...
        31 January 2007, 11:09 Wednesday
      • Karanthes
        825 sub between pre and power amp
        by Karanthes
        I have a Primare SPA21 and A30.2 (surround/power) amps. Have anyone tried using a sub in the 800-series between a pre and power amp? The b&w dealer here said it wasn't optimal, but not surprising had no clue how much distortion or degration of the signal in general I might expect. A mail to b&w...
        28 October 2005, 09:51 Friday
      • ctnsupra1
        Sub or Bass Bins for new Modula build??
        by ctnsupra1
        Well finally after exactly one year of completing my Modula MT crossovers (RS28a tweeter version) I built the boxes. And wow! These things are absolutely incredible in clarity and definition. I've been watching movies and listening to music non stop for the last few days. My question is two parts 1)...
        26 January 2008, 00:03 Saturday
        Bass Management...what's a person to do?
        by Andrew Pratt
        There seems to be a lot of talk lately on what bass management should or should not be doing. It also seems that there are a lot of assumptions being made about what, where and how this BM should be invoked. I came across a few links that are interesting and suggest that the problem isn't with X but...
        28 January 2003, 14:03 Tuesday
