Custom bass trap build
  • ehampshire
    • Nov 2024
    • 10
    Bass Trap Build - https://www.yourmom.sh/basstraps.html
    By Eric Hampshire
    All the photos
    2 weekends have been spent working on bass traps for my 2-channel listening room. I decided to try building them myself to a) save money and b) 3 of the 4 corners of my room have doors so I needed a solution to move the panels into place and out of the way of the doors. I wasn't very confident modifying some commercial ones, so I figured custom building them would turn out better (and I was right)! Here's one of the cheaper options for commercial ones: https://www.acoustimac.com/bass-traps/Acm-bt-all . ~$500 (incl. shipping) for one 96" one. My cost for 4: ~$400
    1) Raw materials
    2) Frames assembled - 96" (8') x 33.25" for the front corners (behind each speaker). 85" x 24" for the rear corners. Each ends up being ~4" deep but the wood on the sides is 6" angled at a 45. I probably should have cut the insulation down as it's 5.5" thick, but it was already a pain to cut + deal with, that wouldn't have been fun. As such the panels are a bit lumpy in parts and I now understand why the professional companies use rigid insulation to give a flatter appearance.
    3) Cross braces installed
    4) Weed paper installed on the back to hold the insulation in
    5) Insulation I used, it absorbs base pretty well! Spec sheet: https://www.owenscorning.com/dms/10025220
    6) Insulation added
    7) 2 smaller, rear panels with insulation added
    8) Fabric I chose. A little too stretchy, I probably should have gone with something that didn't stretch so much, but I was concerned about the "acoustically transparent" part.
    9) Extra material was shoelace'd (?) together with some paracord. I contemplated sewing but I think this actually looks pretty good and was way easier + faster
    10) The back of one of the smaller panels
    11) Leaned in the corners (for listening tests). My listening room has doors in 3 of the 4 corners, so I put them on hinges to swing out of the way of the doors
    12) Fronts sitting upright (but not hung yet). For listening tests, naturally. Yes, they do in fact do their job!
    13) Ok, I probably went overkill with the brackets here which is why I returned the rest of these and bought bigger ones for the rear panels. The white blocks are baseboard material that I cut + painted to match and sit the panel off the wall enough for the hinge to work and it not be sticking out further on the bottom (because of the baseboard).
    14) Another new tool - laser level! Uh, I should have bought one of these way sooner, they make the job so much easier!
    15) Rear panel hung (notice the greatly reduced number of brackets lol)
    16) Halfway closed, I added a velcro strip near the top where the panel hits the door frame so it will stay in place when swung "closed"
    17) Closed position
    18) Without room treatment
    19) With room treatment. Still have quite the dip at 50Hz and spike at 100Hz but not as bad and more even response throughout. I need to play more with the listening position and speaker positions.
  • chrisn
    • 175
    Surprisingly different, didn't expect the top end to change that much! Have you measured with the doors open as well?
      Master of None
      • Jan 2014
      • 1665
      I have a new mic now to measure with. I really need to take some measurements of my room and see where it is at and then look at a DIY project like this. I've wanted to try making panels. Last time I bought, but if I can find the time I think this would be a fun project to do. The hing idea is great too, I will have to come up with that for one of the panels. The door to my room in the back corner.
      Painter in training
      • ehampshire
        • Nov 2024
        • 10
        No, I should try that! Thanks!
        • Club1820
          Acoustic Panels using R13 Insulation?
          by Club1820
          OK. I know that the best option would be to buy Acoustic Panels from a manufacturer such as Real Traps. Or if DIY, then using Corning 703 insulation.
          But who knows if I would ever get around to either one of these options. So, since my basement was recently finished, including...
          26 July 2007, 22:17 Thursday
          Corner bass trap tuned to 45hz
          by TEK
          Hello
          I'm thinking about trying to tame some room modes/bass peaks that I have around 45-50 hz.
          REW's room mode calculator shows that this is expected problem area for my room, and measurements seems to support the same conclusion.
          So I'm thinking about adding bass...
          01 April 2015, 12:08 Wednesday
        • brac
          Starting help-purpose if insulation????
          by brac
          Hey,
          Her is my question, I am building a new HT starting at zero. I don't care about sound in escaping into the rest of the house, so which if any of these thigs are not needed? Thanks
          1) raised floor with insulation.
          2) insulation over concrete walls under...
          28 August 2005, 12:39 Sunday
        • Marzen
          Peg board wall for a bass trap?
          by Marzen
          I was wondering if a peg board wall with unfaced insulation behind it would work as a room deadening device and/or bass trap? I would have it flush with my L/C/R + sub speakers at 12'w x 7'h with a cavity 2' deep. I saw a similar idea using horizontal slats on a rear wall to reduce reflections but...
          19 November 2006, 21:21 Sunday
        • Griffster
          Platform as a Bass Trap?
          by Griffster
          I am getting ready to build a platform for a second row of seats and was wondering if it is possible to use the riser as a bass trap?
          I was thinking of cutting holes in the front and back and stuffing between the studs (2X10) with fiberglass insulation.
          It seems somewhere...
          31 May 2007, 04:41 Thursday
