Finally finished my Curt C Tritrix MTM's!!
  • wjw
    • Jul 2012
    • 6
    Hey all, just posting my long (can someone say 6 weeks?) build from cutting the MDF to the glueing, flush trim bitting, jasper jigging, veneering, cutting, jigging again, filing, sanding, sanding again, staining, aaand finally putting the XOs together and screwing the whole thing all together!!
    Basic box
    Front baffle with the holes almost cut all the way through
    Getting my strap-ons!
    What my glue looked like dried (Tite Bond yellow).
    After I used the flush trim bit (worried look on face here)...
    Filing with a flat file...
    End result
    Hole marked where I had originally put the pilot hole from the jasper jig. My intent was to use the pilot to re-jig the hole the same size as the MDF underneath it.
    Pilot hole that I had already pre-drilled.
    End result, with the hole popped out (I just jigged the bigger hole with the Jasper and pushed the whole button out.
    One coat of Provincial Oak stain on my red oak veneer. I want to match my existing hardwood floor
    One speaker with one coat of stain, the other with two...
    One coat of satin lacquer...
    Six coats of satin lacquer...
    And finally done!!
    Close-up of the brass screws I used for the speakers...
    Am I happy I got it finished? yes. Would I do it again? Heck Ya!
    Opinions appreciated...
    Jim W
    Last edited by theSven; 06 April 2023, 13:37 Thursday. Reason: Update image location
  • john trials
    • 449
    That is a clever way to cut the speaker holes. I cut the holes, then veneered over, then cut the veneer with a blade. It was a pain.
    And 6 weeks for a build...that's fast compared to me!
    Nice looking set of speakers you got there.
    • wjw
      • Jul 2012
      • 6
      Thanks.
      I figured, with the pilot hole/almost cut through/re-do the veneer being the safest, I should do it that way. I would have hated to make he entire cabinet then watch as the little piece in the space between the mid and the tweeter went flying off into the garage wall. This way the holes were cut and I was just routering the thin veneer, therefore no stress on the veneer.
      I also used a satin spray lacquer. Spray, 0000 wool and repeat half a dozen times. No drips, running or mess.
      JW
      • BeerParty
        • 475
        And finally done!!
        I like it! I have never seen set with the round-over on the top instead of the sides, what gave you that idea?
        Last edited by theSven; 06 April 2023, 13:38 Thursday. Reason: Update image location
        My Statement Monitors Build
        My AviaTrix Build
        • wjw
          • Jul 2012
          • 6
          Basically because nobody told me I couldn't do it
          Seriously tho, I never liked (personal opinion here) straight, square boxes as speaker cabs. Never really appealed to me. PS I put some old #8 by 3/4" wood screws in to hold the mids to see what the finished product looked like, and liked the look so much I went out and bought brass... I'll pull the pair of speakers out and take a pic of both 'cause a guy at work is now interested in maybe making them.
          JW
          • KnightsOfNi
            How to. Trim veneer for speaker holes
            by KnightsOfNi
            One questions asked many times on this forum is how to trim the veneer smoothly around speaker holes when the speakers are flush mounted.
            The problem is, because the recesses can be as shallow as 0.100" or so, traditional flush trim bits do not work.
            So what are the options?
            1....
            29 January 2011, 14:18 Saturday
          • kirknelson
            A few finishing questions (Veneer)
            by kirknelson
            I'm about to begin building a pair of NatPs which will eventually be used as surrounds with a the Khanspires/Khancenter. I plan to paint the baffles black and veneer the remaining 5 sides. This will be my first attempt at veneering a project and I have a few questions before I begin.
            22 March 2009, 07:55 Sunday
          • Renron
            by Renron
            Veneer bubbles...
            28 May 2016, 13:35 Saturday
            New in-wall speaker install
            by Andrew Pratt
            I thought I'd post a quick overview of my impressions so far on the new Pinnacle K60 in-wall speakers that I got from our new forum sponsor NextLevelAV on friday. First I must say I've been VERY impressed with NextLevel's owner Jim and his attention to his customers. If this is any indication of how...
            23 January 2005, 13:11 Sunday
          • AvFan
            Nail hole filler and raw veneer
            by AvFan
            I'm building my first set of speakers and trying my hand a veneering for the first time. The construction of the cabinets has not been a problem even though I had a reaction to MDF dust and now use a respirator when working with the stuff. I assembled the cabinets using yellow (PVA II) glue but instead...
            27 July 2009, 22:33 Monday
