I'm about to begin building a pair of NatPs which will eventually be used as surrounds with a the Khanspires/Khancenter. I plan to paint the baffles black and veneer the remaining 5 sides. This will be my first attempt at veneering a project and I have a few questions before I begin.
I plan to use the iron on method.
What is the best way to cut the veneer to get a flush edge (tools?)?
Should I veneer before cutting the hole and recess for the rear port?
How about before/after drilling the holes for the binding posts?
If I veneer afterwards, how do I make a clean circular cut/hole around these openings? How do I prevent the veneer from spliting as I iron around the port opening?
Thanks in advance. I'm sure you've probably answered these questions before but I was unable to find the answers using a search. They are probably buried on page 15 of one of the monster posts here. :E
