My shortcut to glossy black
  • FroDaddy
    • 274
    I wanted to post a few words about how I am accomplishing glossy black on my speakers now. When trying to achieve this by hand, I had a really tough time finishing my Statements. Before starting that project, I scoured the Internet looking for a glossy black shortcut but came up dry. So after all the headaches I was going through on the tower cabinets, my father took it upon himself to try to find something.
    He found a solid laminate surface from http://www.decotonesurfaces.com internal part number FL121GPC070BU, web part number is Formplac L121. You can order samples from them for free as well! They have different levels of gloss and texture, and I ordered two glossy black untextured 4ft x 10ft sheets for about $150! (Hopefully this is okay to post. I'm not affiliated with them in any way, just happy I can share this resource now.)
    In this post I'll discuss how I used this stuff. I'm a novice, so its likely my methods are too! But hopefully this information will be useful to those who are curious about the product.
    Since I ordered 4ft x 10ft sheets, it has to be cut down to manageable sizes first. The plan is to oversize each piece and trim it to fit with a router. The material has a thin panel-board like backing to it, so it is thicker than you'd expect and it is not flexible beyond what you see in the below picture. A paper cutter was used for the oversize cuts:
    Click image for larger version  Name:	papercutter.jpg Views:	3300 Size:	86.8 KB ID:	869977
    I tried using both contact cement and Titebond III on a test piece, and I preferred Titebond III for less mess and easy cleanup. However, the drawback to this was the edges aren't attached as firmly as I expected. I'm sure contact cement would have been a better choice in regards to the application.
    My goal was to put this finish on my 2rCC in one full working day, and I was able to do just that. That's right, glossy black in ONE day!
    I started on the sides of the speaker, applying one at a time. I used a cheap 99c brush to spread the glue on the bare MDF surface, pictures of that are in later posts. Then I'd use a block of wood to apply my full weight to the side for about 5 minutes. Then I flipped the speaker over so the weight of the cabinet would continue to apply pressure, and repeated the application step on the other side:
    Click image for larger version  Name:	sides.jpg Views:	3269 Size:	72.5 KB ID:	869978
    Titebond III recommends a dry time of 30 minutes, so I used this time to prep the router and the surface. Even though this material comes with a protective plastic, it is a MUST to further protect the surface with painters tape and paper:
    Click image for larger version  Name:	protectingTheFinish.jpg Views:	3340 Size:	88.5 KB ID:	869979
    Last edited by theSven; 04 May 2023, 14:48 Thursday. Reason: Update image location
  • FroDaddy
    • 274
    Even after the surface is protected, keep a watchful eye while routing and be conscious in changes in resistance as well. This could mean that routing debris has accumulated enough to pull up your protective surfaces and it will damage the laminate! I used a regular laminate trim bit similar to this one, but with a 7deg angled cut:
    IMPORTANT NOTE: The trim bits' bearings will leave a permanent scar on the surface they are riding on if you don't prep for this! In the next picture, look at the lines on the MDF near the top. This is the router bearings marring the MDF. I discuss how I worked around this later in the thread, but since the raw MDF will be covered I didn't worry about it during this step.
    Here is what a side looked like after the trim:
    The pictures are a little bit out of order at this point, but the idea is contiguous. Here is a picture of a bare MDF side; yes this means no prep work at all! Just wipe with a damp cloth to remove MDF dust. Notice the perpendicular edges have the painters protection peeled back some. This is because the edges are feathered from the trimming, and they will get glued to the perpendicular edge.
    Now for some glue:
    The surface is evenly spread with glue using a cheap 99c brush. Excess glue was wiped from the brush with a paper towel, and some added where necessary:
    Last edited by theSven; 16 March 2023, 20:06 Thursday. Reason: Update image location
    • FroDaddy
      • 274
      Using the same method as said above, I applied pressure to the sides by hand and once the set time was exceeded weight was added to the side during the dry time. I let it set for 45 minutes instead of the recommended 30 minutes. You could use clamps and pieces of wood if so inclined, but I just grabbed heavy items around the workshop instead:
      Now that all of the sides were laminated and dried, it was time to trim all of the edges. The bulk of the work for me was in the detail trimming. Since I don't have a trim router, I was using a big 2.5HP router for the process. I'm not sure if a trim router would have made this easier, but I got the job done with a bigger router anyway.
      As said in an earlier post, the bearings on my flush trim bits will eat right through the protective finish; even with 3 layers of painters tape on top of it. I don't have a picture of the trimming process, but here is a description:
      • I used a scrap piece of laminate and held it in place with painters tape. This way the edge of the trim bit rides on a surface that can be marred.
      • Again, the surface that the router rode on was protected with painters tape and paper.
      • I would do an initial pass to trim the excess laminate off
      • I then used a 45deg chamfer bit and very VERY carefully put a 45deg edge where the laminate meets. The bearing for this bit also rode on a scrap piece of laminate.
      After all of the edges were trimmed and chamfered, I began working on the holes. I absolutely 1000% recommend applying the laminate first, and THEN routing the speaker holes! (This is the normal way to do this.) But since the 2rCC was designed with bare MDF, I didn't have that luxury. Using the same bit as pictured above, I took the advice from Jed and tried to grind down the bottom of the bit using a grinder. This was so the cutting edge would be low enough in the driver recesses to cut the laminate flush.
      I doubled up the protective painters paper/tape since the router would be cutting circles, and this was absolutely necessary. I avoided a disaster by doubling it up! Here is how it looked after all trimming was done:
      I mounted the speakers and then peeled away the plastic protective coating. Since all of the edges were trimmed, you will have the laminate bare edges exposed as in this picture below. I got to this point in ONE day!
      I went to an arts and crafts store, and found a Testors brand enamel paint pen in their model cars section. I used this pen to make one pass on the edges to put the finishing touch on the 45deg laminate edges. I also used this to paint pen to paint the bare MDF / laminate in the driver cutouts. Here is the finished result:
      Last edited by theSven; 16 March 2023, 20:04 Thursday. Reason: Update image location
      • FroDaddy
        • 274
        Another use for the laminate
        I actually first used the laminate as an inlay for my Statement bases. I tested what depth I needed route, and once that was set I routed off a layer on the top of the bases. (Of course the stain was done after the routing was completed.) The sides of the bases are iron-on veneer edge trim from Woodcraft:
        It was tough to cut the laminate inlay to fit, but after trial and error I was able to cut to 1/32in so that each side had 1/64in margin of error.
        After the glue was spread, I applied weight:
        Last edited by theSven; 04 May 2023, 14:47 Thursday. Reason: Update image location
        • FroDaddy
          • 274
          Now the edges need to be trimmed using the methods described earlier:
          Here the edges are trimmed with the router as well as the port hole, the protective plastic was removed, and the edges were ready for the paint pen. (I don't have a good close-up after the edge had the paint pen applied, but it looks like the center channel edges now.)
          Last edited by theSven; 16 March 2023, 20:03 Thursday. Reason: Update image location
            Great posts.
            Eventually, this should probably get moved to the FAQ / Reference Threads section.
            • FroDaddy
              • 274
              Great posts.
              Thanks ---k---! I'd be interested to learn how an experienced wood worker would improve on my methods, or how other people would integrate this into their projects.
              But even if I'm the only one who will use the material, I'm thrilled it exists and will finish my Mini Statement surrounds with it as well. I still can't believe how inexpensive this material is!
                Appears to be a high-pressure laminate like Formica, Wilsonart, Nevamar, etc....
                • wackii
                  • 226
                  Frodaddy,
                  Wow. Excellent. Thanks for the details write-up. I might give this method a try if I can gather some funds for the Statements. My arms/hands will thank you for this
                  Al,
                  • Operandi
                    • 145
                    When I saw the speaker prior to touch up with the MDF peaking out I said "meh"...
                    Then I saw the final result; "wow!" That looks really seamless, very nice work .
                    • bbcmp1979
                      • Dec 2009
                      • 173
                      Wow.. amazing finish.
                        • 16209
                        Nice work- thanks for shaing in your post! May save some folks a lot of effort and time! :T
                        • xyrium
                          • 118
                          OMG, brilliant! Now I know what my crossover boxes will be covered in!
                          Paul
                          • DoubleTap
                            • Dec 2009
                            • 34
                            How does this compare to the FX Sheeting?
                            • FroDaddy
                              • 274
                              I'm not familiar with that product?
                              I'm going to use this method as a finish to 4 Mini Statement surrounds in April, too. Thanks for the kind words
                              • schnottus
                                • Oct 2009
                                • 9
                                The 150 dollars for two sheets, was that with or without shipping? I can't imagine 4 by 10 sheets were cheap to move.
                                  • 1456
                                  It looks like most of their stuff is about 1/32" thick, so I'm guessing it can probably be rolled into a reasonable size box just like wood veneer, which should keep the shipping cost reasonable.
                                  Dan N.
                                  • dawaro
                                    • 263
                                    Nice write up. If I may offer a little advice try using one of these router bits. They have a square teflon bearing that rides on the surface rather than spinning so you dont get the marring on the surface associated with other bits.
                                    • FroDaddy
                                      • 274
                                      dawaro I'm liking that bit Thanks for the lead I'm going to buy one
                                      schnottus, dlneubec was correct in that they roll the sheets to keep everything reasonable.
                                        Nice work! Yes, Thomas, WilsonArt has it and for a unique touch, I'm interested their Metalaminates also: http://samples.wilsonart.com/c-8-decorative-metals.aspx
                                        Dawaro: thanks for the bit tip - I like the idea of the non-spinning teflon bearing.
                                        • dumaresq
                                          • Mar 2008
                                          • 96
                                          what exactly was the pen you used to "touch up"?
                                          If you were doing normal veneering how does one avoid the having to do the touch up step?
                                          • FroDaddy
                                            • 274
                                            It's a Testors enamel paint pen that is used for model cars. It has a felt tip that soaks up the paint.
                                            With veneer you wouldn't have to since veneer is wood throughout. When you stain the veneer it takes care of the edges.
                                            • dumaresq
                                              • Mar 2008
                                              • 96
                                              I guess question I have about the paint is how did you match the color?
                                              • FroDaddy
                                                • 274
                                                It's not matched perfectly, the pen will apply a matte black finish on the edges. I used several test pieces with different paint pens to get the most correct shade of black, and then a few more to learn the application method of the Testors. Definitely use a test piece to learn how to apply it, and if you're not using the same formica material I'd suggest trying different paint pens for color matching.
                                                What this is doing is essentially tricking the eye. Our vision is based off of contrasts, and there isn't enough thickness in the material nor color variation for the eye to detect anything. In fact, I think the paint pen edging looks better blended than my stained edges do. Pictures tend to reveal everything, so in person the blend is even less detectable. A lighter edge than the surface material is what you're after, but dark enough to cover up the wood color.
                                                Thanks, HTH
                                                • TurboFC3S
                                                  Cabinet rebuild progress ...
                                                  by TurboFC3S
                                                  I just want to show what can be done for those of us with nowhere to work on building cabinets from scratch. I've been doing this on my kitchen floor and the back porch.
                                                  These cabs started life as Wharfedale Emerald 87's. It's a 2.5 way, the cab was decently well constructed with...
                                                  06 February 2007, 16:01 Tuesday
                                                • thasqgotme
                                                  Finishing Walnut Cabinets?
                                                  by thasqgotme
                                                  I just ordered all of my drivers and crossover parts today for the Shticks. I also went to my local wood shop and had them rough cut my panels out of 1/2" Walnut plywood. Luckily they had some perfect 4'x4' scraps of that stuff, because they wanted $120 a sheet for it.
                                                  The sides...
                                                  09 January 2009, 23:00 Friday
                                                • megamuel
                                                  Veneer trimming problem
                                                  by megamuel
                                                  Hi guys,
                                                  I'm in the process of veneering my speakers and I've hit a few problems that didn't occur on my test pieces. I'm using raw mahogany veneer (could not find wide enough backed veneer in UK!) and I'm using a normal flush trim router bit to trim the edges. The bit is new so it will...
                                                  16 April 2008, 11:57 Wednesday
                                                • warnerwh
                                                  Would someone run some numbers please?
                                                  by warnerwh
                                                  I'm curious as to the frequency response of this subwoofer I'm building. The box internal volume is 8.5 cu ft. The driver is the Dayton 15" high fidelity.
                                                  What I'd like to know is how to adjust my Behringer DEQ 2496 to make the Q .5.
                                                  Btw all is coming along well. Haven't downloaded...
                                                  14 December 2006, 01:07 Thursday
                                                • Amphiprion
                                                  Laminate cutting shears
                                                  by Amphiprion
                                                  Just a little experiential post here, but I bought some laminate cutting shears from Lowes to cut some WilsonArt laminate I am using on a sub project. I'd heard good things about laminate shears, but I must have bought the wrong brand. They suck. The old score'n'snap method with a carpet knife is much...
                                                  18 August 2006, 19:01 Friday
