I just ordered all of my drivers and crossover parts today for the Shticks. I also went to my local wood shop and had them rough cut my panels out of 1/2" Walnut plywood. Luckily they had some perfect 4'x4' scraps of that stuff, because they wanted $120 a sheet for it.
The sides of the Walnut obviously have that layered plywood look to them. Is there a trick to getting them to match the surface? What do you guys do to hide them?
Also, what kind of router bit do you guys use to trim the edges of the cabinet flush?
Thanks again :T
Thanks again :T
