BAMTM build thread
  • savage25xtreme
    • 305
    BAMTM build thread
    was ordering my goodies when I got to the tweeters I noticed madi is out of them. I am correct in assuming they are just out of stock and will get more in? SEAS Prestige 27TBFC/G madi part number H1212 is the correct tweeter right? any insight or alternate vendors would be appriciated.
    Gavin
    BAMTM Build
    • savage25xtreme
      • 305
      Thanks again Thomas. I will get some pics posted of the enclosure this weekend :T
      Gavin
      BAMTM Build
      • savage25xtreme
        • 305
        quick update: ordered the crossover parts from madisound, the tweeters from meniscus, and the rest of the parts from partsexpress including Dayton binding posts and Acousta-Stuf and with shipping for everything to 73533 it came out to $300.74 if anyone else is interested is building these.
        Gavin
        BAMTM Build
        • HareBrained
          • Jul 2008
          • 230
          You must have gotten the last pair of the 27's, Meniscus now lists it as out-of-stock.
          John
          • savage25xtreme
            • 305
            I will consider myself lucky :W
            I will put them to good use!
            Gavin
            BAMTM Build
            • cheno848
              • Feb 2009
              I have a single H1212 if anybody only needs one.
              Keep us updated on the build savage, I built a pair of these and love them.
              • savage25xtreme
                • 305
                I got all my MDF cut today, I am doing the 1cu-ft sealed like what is on Zaph's page. couple of questions. the baffle on the PE enclosure is 1/2" and mine is 3/4" can I do a 3/4 round over on the edge? or will it hit the drivers cut out? how big are the holes in the brace? spacing for holes in the brace? I did some research and found that binding posts are suppose to be 3/4" on center for spacing. I am going to do a 45 chamfer on the back of the driver cut outs, should I just do about the back 1/2" of the cut out? I downloaded the drivers spec sheets, are those really close on the holes sizes and flange thickness? should I use those measurements or wait til my drivers get here and measure myself?
                Ill throw some pics in here tomorrow.
                Thanks in advance,
                Gavin
                Gavin
                BAMTM Build
                • savage25xtreme
                  • 305
                  I found the drawing on the PE's website that has most of my answers.
                  Gavin
                  BAMTM Build
                    One should always wait until the drivers are in hand...
                    • savage25xtreme
                      • 305
                      ok, will do. how much of the back of the driver opening should i put a 45 degree on if my baffles are 3/4 thick? can you comment on that? I think I have found answers to all my other questions thus far.
                      Gavin
                      BAMTM Build
                        Different drivers but the idea is the same...
                        Click image for larger version  Name:	petra03.webp Views:	1 Size:	70.3 KB ID:	941763
                        Last edited by theSven; 24 June 2023, 15:52 Saturday. Reason: Update image location
                        • savage25xtreme
                          • 305
                          So I called Meniscus today because my order still said "processing" and they said they are actually on back order there, probably for another week or two :evil: . could anyone point me in the direction of another vendor?
                          Gavin
                          BAMTM Build
                          • drab
                            • Jan 2009
                            • 11
                            I must have bought the last ones then. :twisted:
                            I ordered them last Monday from Meniscus and received them on Friday. :
                            Mike
                            BAMTM build
                            • drab
                              • Jan 2009
                              • 11
                              ThomasW
                              Is it ok to roundover the inside of the drivers' holes or
                              is it better to chamfer them?
                              Mike
                              BAMTM build
                                http://www.zalytron.com/seas.html
                                chamfer or round-over, either one is fine.
                                • drab
                                  • Jan 2009
                                  • 11
                                  Thanks! :T
                                  BAMTM build
                                  • savage25xtreme
                                    • 305
                                    thanks for the link Thomas, got some routering and gluing done last night... I have a new respect for you guys that build perfect cabinets
                                    I also learned the hard way to put the pivot pin for the circle jig down into your work bench so when you cut the last of the work piece it doesnt grab the side of your brace and go crazy... atleast I figured this out before I started on the baffles.
                                    Last edited by theSven; 24 June 2023, 15:53 Saturday. Reason: Update image location
                                    Gavin
                                    BAMTM Build
                                    • savage25xtreme
                                      • 305
                                      just called Zalytron and they had them in stock, you saved the day Thomas, and they were 20 cents cheaper 8) thanks again.
                                      Gavin
                                      BAMTM Build
                                      • savage25xtreme
                                        • 305
                                        got my baffles and one of my cabinets done last night minus the sanding. on the baffle, once I glue it on I was going to round the edges over with a 3/4 round over so it will follow the cabinet profile perfectly... right now its a little big (about 1/16th all the way around). this will basically put the round over to within 1/4" of the edge of the driver cutouts. is that OK? would it be better to just do a 1/2 round over like the PE cabinets have? also my baffle is only 3/4 thick verses 1 inch thick on the PE cabinet.
                                        any advice would be much appreciated on a rookies first build :T
                                        Gavin
                                        BAMTM Build
                                        • savage25xtreme
                                          • 305
                                          also... would this be a better inductor to use for L2? with its much lower DCR for about the same price?
                                          Gavin
                                          BAMTM Build
                                            Buy a flush trim bit. It has a roller bearing on the bottom. Use it to make the edges flush with the panels.
                                            !/2" vs 3/4" round-over isn't important
                                            Do you really have a 3/4" roundover bit? Those only come with a 1/2" shafts.
                                            Unless he screwed up (unlikely) Zaph calculated the resistance of the inductor into his design, so no don't change it.
                                            • savage25xtreme
                                              • 305
                                              in his options section he models this inductor with 3 different DCR values... as the resistance gets lower the sensitivity of the woofers gets better... and the least resistance value he plotted was .15 ohms. the one he specs out is .47ohms which has the worst sensitivity.
                                              I told some advice from Jim Holtz and all my bits are 1/2 shaft and whiteside. I have been extremely pleased with them thus far.
                                              Gavin
                                              BAMTM Build
                                              • drab
                                                • Jan 2009
                                                • 11
                                                He does have different dcr values as an option for L2. Lowering the dcr directly affects the Qts and sensativity.
                                                He has measurements posted for different dcr values under options. You have to decide if it's worth the money.
                                                For me it was worth the extra few bucks for my own mental stability.
                                                Mike
                                                Edit: You already knew this. :roll:
                                                Last edited by drab; 01 April 2009, 17:38 Wednesday. Reason: Too late. Yes I type that slow
                                                BAMTM build
                                                • savage25xtreme
                                                  • 305
                                                  it was 16 dollars for the madisound sidewinder I got... the one in the link above is only 17 something...
                                                  I have been looking at your build pics drab, do you have a build thread somewhere?
                                                  Gavin
                                                  BAMTM Build
                                                  • savage25xtreme
                                                    • 305
                                                    quick update: my tweeters wont be here til lext tuesday but i got one of the cabinets done and one of the crossovers done and both baffles minus the tweeter holes of course.
                                                    45 degree i put on the back of the woofer holes
                                                    clamping the side and brace in
                                                    after the first woofer hole was cut i test fit a driver and it was too loose for my liking so i broke out the calipers and micrometer and got the next 3 holes to within .005 of the diameter of each driver.
                                                    how does this crossover look? inductors should be good according to the chart I saw somewhere.
                                                    having a blast :T
                                                    Last edited by theSven; 24 June 2023, 15:55 Saturday. Reason: Update image location
                                                    Gavin
                                                    BAMTM Build
                                                    • Smokinghot
                                                      • 85
                                                      Click image for larger version  Name:	BAMTM008.webp Views:	0 Size:	30.6 KB ID:	942323
                                                      Sweet.... ;x(
                                                      • drab
                                                        • Jan 2009
                                                        • 11
                                                        Wow! You're a better cabinet builder and photographer than I am. ;x(
                                                        Keep the pictures coming.
                                                        Mike
                                                        Ps: Nice bike. :T
                                                        BAMTM build
                                                          Thing is you need to leave enough 'meat' for the driver mounting screws.... that's why I posted this picture a while back...
                                                          Last edited by theSven; 24 June 2023, 15:57 Saturday. Reason: Update image location
                                                          • savage25xtreme
                                                            • 305
                                                            kind of hard to see in the pic but I left about .3" on the front flat... with no 45 and the way it looks to me I will have a little over a half inch of meat. If it does not hold I have enough scrap to do 2 more baffles. Its all a learning process.
                                                            thanks for the kind words drab and smokinghot.
                                                            the bike is absolutely covered in MDF dust :P
                                                            Gavin
                                                            Gavin
                                                            BAMTM Build
                                                            • savage25xtreme
                                                              • 305
                                                              how do I know if they will hold? if with the gasket tape in there the drivers suck down to tight? any other signs I should look for?
                                                              I also just noticed my inductors ARE facing the wrong way.... DOH I'll fix it when I get home.
                                                              Gavin
                                                              BAMTM Build
                                                              • HareBrained
        • Jul 2008
        • 230
        I believe Thomas is referring to the scalloped relief on his baffle verses the continuous chamber of yours. Behind the screws, his have a full baffle depth of holding power while yours is shallower.
        John
        • 16176
        Really nice tight fit on for the drivers and baffle rabbet, but what if you want to paint the baffles? What then? :W
        • savage25xtreme
        • 305
        ya i realize what he is talking about, I just wasn't sure if mine will hold or should I start over?
        Gavin
        BAMTM Build
        • savage25xtreme
        • 305
        I was going to put a coat black primer in the cut out then mask it off for painting the rest....will that not work?
        Gavin
        BAMTM Build
        Those are baffles from one of Brandon's projects. You're correct about the scalloping, that's why I posted the pics.
        • drab
        • Jan 2009
        • 11
        I think it will hold just fine.
        I think that will work too. :dancenana:
        Mike
        BAMTM build
        • savage25xtreme
        • 305
        I got one of the crossovers done and mounted and got my tweeters in Friday so I decided to clamp one of the baffles on and set the drivers in there to make sure I wired everything right.... I was VERY pleased with how they sounded and I was way to close to the speaker and I only had one going... cant wait til they are both done :T
        For these sealed enclosures should I put a bead of silicone around the inside to make sure they are sealed good?
        Last edited by theSven; 24 June 2023, 15:58 Saturday. Reason: Update image location
        Gavin
        BAMTM Build
        I usually do that. Instead of silicone I use a siliconized latex caulk. It's cheap, cleans up with water, and doesn't off-gas anything nasty.
        • savage25xtreme
        • 305
        good deal I think I have some of that left over from a bathroom job. :B
        Gavin
        BAMTM Build
        • Mornlith
        • Sep 2008
        • 9
        Hey all..I've surfaced from my bathroom reno...now I can return to figuring out what to build.
        Savage: What are you going to use the BAMTM's for? HT? If so, what are you going to do for a CC? Just curious. Build looks sweet so far. I noticed some Polk's in one of your pics and would be curious to hear how the "budget" speakers compare.
        • savage25xtreme
        • 305
        I am probably going to put the BAMTMs in the garage with a CD player... and build some Statements for my HT room. I will be sure are write a full review when I get both build, but they are going to blow my lil polks away. I picked those polks up for 200 bucks at Fry's on sale one day... they just barely make enough noise to be called speakers haha
        I have a very hard time turning my one BAMTM off last night, so much fun to hear little details I have not heard. and i found that one of my burned copies of Tool 10,000 Days was a horrible copy, horribly staticy that I never heard on the polks. I feel this first DIY speaker build is the beginning of the end for me. I am hooked.
        Gavin
        BAMTM Build
        • savage25xtreme
        • 305
        got the cabinets caulked up last night and both crossovers are now done and mounted. I used one screw right in the middle to mount them which holds them really well, and I don't think it will bother the inductors, or am I wrong? tonight I will stuff the cabinets and drill pilot holes for the drivers in the baffles then glue them on and start the finishing process.
        one sack of AcoustaStuf should be enough for both cabinets right? any advice on how to put it in? on Zaph's website is just says stuff liberally and stay 5 inches from the midwoofers.
        Last edited by theSven; 24 June 2023, 15:59 Saturday. Reason: Update image location
        Gavin
        BAMTM Build
        • savage25xtreme
        • 305
        glue stuffing to the sides by that baffles? who knows?
        Last edited by theSven; 24 June 2023, 16:05 Saturday. Reason: Update image location
        Gavin
        BAMTM Build
        No need to do that. What you have done is fine.
        • cobbpa
        BAMTM--slight mods / shoehorning...
        by cobbpa
        So I have 4 DA-175's sitting idle and a craving to make some sawdust. Gotta be Zaph's BAMTM, right? My specific challenge, though: these will first go on a wall/mantle, then into what is essentially another shelf/near-wall location.
        I haven't been around for a while, but I can guess...
        08 September 2009, 21:44 Tuesday
        • deucelee
        budget towers - TriTrix vs. BAMTM
        by deucelee
        hey guys,
        my bro's asking me to build him a set of budget towers with the potential to add a center and two rear MT's for HT in the future...
        we're looking at curts tritrix and zaph's bamtm...
        looks wise, the nod goes to the BAMTM's, they also have a 1.5...
        01 January 2009, 18:53 Thursday
        • clearwaterms
        HT front, which speakers, Audax HT, Modula Mt's, Natalie P's, BAMTM? please help
        by clearwaterms
        okay,
        I am new to the DIY audio community but am chomping at the bit as to which project to try first. let me start by saying that I am trying to accomplish. i am trying to build the front three speakers for my home theatre. I would like some advice. The way I see it is that I have...
        26 December 2006, 17:01 Tuesday
        • cobbpa
        My Zaph BAMTM build & CJD MTM Re-build
        by cobbpa
        Only a final pic here, but I'll add some commentary--sorry I didn't snap many pics during the build. But below is the finished product, 2 of Zaph's BAMTM speakers & a re-build of CJD's MTM as a center. All of these are lower BSC to be placed near-wall. Next step will be to assemble a shelf or mantle...
        20 March 2010, 14:50 Saturday
        • chibahawk
        BAMTM For A Clueless/HT-Less Guy
        by chibahawk
        Right now I'm watching a movie (Snatch) on a 50" rear projected LCD Sony. It looks good. However my current HT if you want to call it that is a relic from when I knew nothing about tech - it's some 5.1 Sony DVD receiver and it's time to get rid of it.
        For starters - What is MTM?...
        22 May 2007, 19:05 Tuesday
