Need Amplifier for Jim Holtz's: Anthology Towers
  • benniehanas
    • Jan 2016
    • 3
    Hello, I just got this kit with the recommended capacitor upgrades and such and will be building once I move. I listen to music, but also like movies and am eyeballing a pair of HS-24 subs by stereointegrity further down the road. I will be getting things as I can afford them and the next in line before the preamp are monoblocks. Anyone have any experience with these? Anyone recomend a good preamp to use with these monoblocks, or better a DAC that is also a good preamp? I need something to power these and have been looking towards Schiit Tyr Amps and am wondering it they will provide enough power. They are rated as follows:
    8 Ohms: 200W RMS per channel maximum
    4 Ohms: 350W RMS per channel maximum
    Frequency Response: 20Hz-20Khz, -0.1db, 3Hz-500KHz, -3dB
    THD: <0.01%, 20Hz-20KHz, at 200W RMS into 8 ohms
    IMD: <0.01%, CCIR, at 200W RMS into 8 ohms
    SNR: >120db, A-weighted, referenced to full output
    Damping Factor: >200 into 8 ohms, 20-20kHz
    Gain: 22 (28dB)
    Input Sensitivity: AKA Rated Output (Vrms)/Rated Gain. Or, 40/22. You do the math.
    Input Impedance: 47k ohms SE, 47k ohms balanced
    Inputs: RCA for SE input, XLR for balanced input, rear panel switchable
    Topology: Nexus™ discrete differential current feedback gain stage, no coupling capacitors or DC servos with Continuity™ constant transconductance output stage, all BJT output
    Oversight: microprocessor-controlled monitoring and management of critical operational points, including DC offset, with standby mode and relay shut-down for overcurrent, thermal, and other faults
    Power Supply: 600VA transformer with 600VA choke input to main rails, plus boosted, regulated supply to input, voltage gain and driver stages, plus separate, isolated and regulated rails for microprocessor management.​
    Master of None
    • Jan 2014
    • 1662
    Gain: 22 (28dB)
    Do you have a link for the kit that you got?
    I'm just getting into the DAC experience and would not be able to make any recommendations that would be helpful. I have a Soekris 2541 that I got 2 weeks ago and I have started to experiment with the DAC. Pre-amps, I have no experience to date. My journey began in the home theater side and then this forum grew my interest in 2.0 and that journey is just beginning now after building my last project the SMJ Ardent D's. I have a setup for theater, and then I have to switch the XLR cables from the Theater processor to the DAC for the 2.0 listening.
    Looking forward to read what other members would recommend for a DAC or pre-amp setup.
    Painter in training
    • benniehanas
      benniehanas commented
      Editing a comment
      I got from madisoundspeakerstore.com. I had a 2.0 kit from speakerdesignworks. Their TriTrix MTM. I would always look behind the couch to the front door when a knock at the door was in a movie! sounded better than 5.1 but with only 2 speakers. It was my first build and ugly hehehe. Wife forced me to finally get rid of them. Weird how 3D better 2.0 towers can sound.
  • eb15
    • 54
    That's actually a little more power amp than the speaker will handle, but it should be fine for most circumstances (if you don't go crazy with bass boost and loudness).
    The anthology uses 2 RS225s in parallel, so 2 times 80Wrms rating = 160W into 4 ohms or using the peak power spec of 160W x 2 = 320W peak into 4ohms.
    • Heli-Tim
      • Nov 2015
      • 164
      I'm building the same pair of speakers! I ended up building a custom amp for them . Prior to that, I was looking at Emotivas XPA line-up.
      This hobby gets expensive fast!
      • benniehanas
        Editing a comment
        Yea it does. Like 5k so far, and still no DAC or preamp
    • benniehanas
      • Jan 2016
      • 3
      Ok, thanks, I was looking for an amp that I didn't need to push past half on the nob for peak sound. This seems it will do it I guess
        New Z-series DAC finally released!
        This is sweet--the zDAC is finally released. I'm going to pick up a couple of these for sure, and I'm REALLY hopeful about the performance possibilities.
        News release today. Visit the full press release webpage at http://www.gspr.com/parasound/zdac.html for high resolution pictures...
        06 November 2012, 09:17 Tuesday
      • deewan
        Deewan's Anthology II (LCR) with Bromo (surround speakers) build thread
        by deewan
        Greetings all. I've been out of the DIY speaker kit scene for a bit. My last build was a Statement II custom cabinet build 8 years ago. I recently sold my home and the new owners wanted to purchase all my theater gear and DIY speakers. I find myself with nothing more than a Sonos ARC and Sonos sub to...
        24 March 2023, 14:40 Friday
      • matt12v
        buttkicker amp at 8 ohms anybody?
        by matt12v
        Does anybody know how much power the buttkicker amp outputs @ an 8 ohm load. Is it not recommended to use it at 8 ohms? I am running it on 1 TC-2000 dual 4 ohm 15" but I dont exactly want to run 2000w rms @ 2 ohms into it lol. Any suggestions? Thanks
        22 July 2008, 17:15 Tuesday
      • Dilirium
        My Anthology's build
        by Dilirium
        Hi all, I am new to this forum and I just recently started my Anthology's. I have a set of Dali Concept's now and I want something better.
        At first I planned to build the Statement II speaker but those were rejected by my better half due to their size. I really like the Statement design of Spleen21...
        26 January 2018, 15:36 Friday
      • Chrissi
        Anthology II Adventure
        by Chrissi
        This began as a upgrade project to a mostly home theater (HT) arrangement we have which is a hodgepodge of Yamaha receiver, 12" Mono Sub. Bose 6 and Bose center bar with Bose 101's as rear and rear center speakers. The Anthology II's will for some time to come be above the grade of the other components...
        30 October 2023, 12:35 Monday
