ANYONE OWN AN LG 52SZ8R, I NEED YOUR ''HELP" PLEASE
  • avrtRick
    • 63
    I am in dire need of the service menu defaults for this display,
    In my attemp to reset the lamp counter(which was'nt even in the service menu)I have stuffed with some settings and really need to correct my IDIOTIC mistake. ops: ops: :cry: :cry: :cry:
    Is there anyone that can help by providing this information so I can fix it.
    This display belongs to my perants and I feel like such an ASS for doing it.
    The problem is with the colors and I need the default settings for the "AUTORGB{hex} and the defaults for the "CCA" settings as well.
    Something happened so quick and then I fiddled more which I shouldn't have,
    but it is better than what was,but still not right.
    Any help with this and my appreciation would go beyond further that what I could say
    I have posted on AVS,AUSSIE DTV and now here
    Hope someone can help!!!
    thanks
    Rick
    Twin Moderator Emeritus
    • 16706
    Sorry to hear Rick, unfortunately I don't own one or know the defaults but good luck.
    If all else fails, you could try contacting LG or a local ISF tech.
    • avrtRick
      • 63
      Thanks Jason,
      I went back into those settings and got them pretty good, but not like they were before hand,my parents are happy,but I'm not,they still need attension!!
      But I will say I think I done pretty good to get them where they are now.
      It is still a little biased towards red(on peoples faces,but not on all programs) and blues are a bit Off as well.
      And the overall brightness is not right,by that I mean it needs to be brighter than what it is.
      If all else fails I will pay for a tech to come out and fix it,but I will exhaust every other avenue first.
      Also,my brother has a LG 56"DLP,and I thought I could go off his settings and and tweak it from there.
      There might be slight differences due to the size variation(4") but I think that could help.
      But the initial post still stands, if anyone has any info,please let me know
      Rick
      • cnaltaylor
        DSP 1098 - looses all settings after power cut
        by cnaltaylor
        I have a DSP-1098, what a wonderful piece of gear !
        I do have an issue and I am interested to hear if anyone else has suffered this problem.
        We had a power cut recently and my 1098 lost all the personal settings and resorted back to the factory defaults.
        I have...
        03 February 2005, 00:11 Thursday
      • KennyG
        HTPC settings...and defaults.
        by KennyG
        A couple of things are drivin' me nuts.
        First my Elsa settings won't stay where I set them, after a reboot all settings are back to default.
        I go into the Elsa's advanced "color control" section, set my brightness, contrast, color level and hue where I want them, hit "apply",...
        14 January 2001, 01:58 Sunday
      • Blindamood
        Recording your processor settings...a little help
        by Blindamood
        So, you've spent all that time tweaking your system until it is just perfect. Then, you upgrade to the latest software revision and reset the unit to the factory defaults. BOOM, all of those settings you so carefully entered are all gone. Back to square one....right?
        Well, in an effort...
        02 November 2006, 11:08 Thursday
      • rickp
        DVD A and SACD input settings
        by rickp
        I have just tried my firsta DVD A and I am not sure everything is set properly. I would appreciate if someone could advise what all the various menu settings should be in the RDC 7.
        When I tried to do the level settings from the player, I could only get outputs from FR and FL, but it...
        29 November 2003, 17:24 Saturday
      • scottnv
        Rotel 1066 BM and sub settings??
        by scottnv
        I have a couple of questions for the group out there:
        I notice the RSP-1066 seems to have two subwoofer settings - you can adjust the sub setting in the test tone screen and also you can adjust it in the subwoofer setting screen. Are these two screens interactive - if you adjust the sub...
        24 June 2003, 13:16 Tuesday
