So, you've spent all that time tweaking your system until it is just perfect. Then, you upgrade to the latest software revision and reset the unit to the factory defaults. BOOM, all of those settings you so carefully entered are all gone. Back to square one....right?
Well, in an effort to help those with a Rotel processor (specifically, the RSP-1068) keep an accurate record of their configuration settings, I have created a custom form to ease the task.
Feel free to use the attached form, and let me know if you find any discrepencies. All settings should be listed, as of the latest software revision (1.2.5).
I'm not sure of the differences between the RSP-1068 vs. other Rotel processors and receivers, but I might consider creating other versions of the form, if you can supply the information.
Enjoy.
Enjoy.
