DVD A and SACD input settings
  • rickp
    • Jul 2003
    • 7
    I have just tried my firsta DVD A and I am not sure everything is set properly. I would appreciate if someone could advise what all the various menu settings should be in the RDC 7.
    When I tried to do the level settings from the player, I could only get outputs from FR and FL, but it also played the respective surr channels at the same time. I could not get a center, sub, or surr to play on their own.
    If you should accept this mission of mercy, please be specific and complete as you can.
    (The speakers are all working on playback of the DVD. ) It sounds good but I don't know if I am all the way there or not.
    Rick
  • Burke Strickland
    • Sep 2001
    • 3159
    Rick –
    First, it is hard to know how the test tones should be handled from the DVD-A player without knowing which DVD-A player you are using. Using the test tones generated from my DVD-A player was kind of tricky until I got the hang of how its remote’s directional selection buttons worked. Since you got sound from the surrounds at the same time as the front speakers, I wonder if you had the RDC-7’s DSP mode set to All Channel Stereo and were using digital inputs instead of the multichannel input while running the test tones?
    To confirm that your system is set up for DVD and/or SACD playback, the first thing you need to do with the RDC-7 is double check the sequence of connections from the player to the 6-RCA-to-DB25 adaptor. (I had to re-check mine – in dim light it is easy to confuse the colors that identify the channels.) Page 16 of the RDC-7 user guide illustrates the connections. Here’s how they line up:
    Left Front - Blue
    Right Front - Red
    Center - Green
    Left (Side) Surround - Black
    Right (Side) Surround - Yellow
    Subwoofer - Brown
    Of course, those color codes assume you are using the provided adaptor. If those are not hooked up correctly, you will get some strange-sounding results. :>)
    After you have the cables connected correctly and securely, you will need to set the input for multichannel.
    • Select the input you plan to use for “multichannel” playback. (Even though it is my DVD player, I set up a different one for multichannel, so I don’t have to remember which settings to change each time I play a SACD or DVD-A).
    • Press “OSD Menu” You will need to go to the menu area 2, Input Setup. Item 2-2 is Multichannel Setup. Change that to “Yes” and then quit (press “OSD Menu” on the remote).
    • Then press the “Audio” button on the remote, which is about halfway along the far left edge under the directional circle of buttons (just left of the “Exit Return” button.) It will toggle through a couple or three choices. The one you want is “Multichannel”. (If you change the player’s output to a digital output -- which would NOT be DVD-A or SACD -- then you would need to use the “Audio” button again to select a coax or optical digital input, since Multichannel is analog only.)
    Hope this helps.
    Enjoy,
    Burke
    • rickp
      • Jul 2003
      • 7
      Burke,
      Thanks for the help. I may have had the D/A input in the wrong position yesterday, though I was aware of that little buttons function. I just was playing it again before I read this, so I will have to check about the surrounds playing at the test tone for the fronts again. I did try resetting volumes though and still got no output from the surrounds alone, but from the center worked this time and not yesterday.
      The player is Toshiba 4700. i think. The set up menu in it shows the speakers highlighted as they produce test tones, still no sound though it shows they are getting a signal. Visually anyway!! And they do work on playback.
      I had already double checked the connections in the back. They are ok.
      Thats a great tip on the separate input for the analog. I was dreading forgetting to reset someday and then not knowing what the heck is wrong a few days later for a flick.
      Were you aware of being able to adjust levels of the channels on the fly in this analog mode? I just read about it yesterday but haven't figured out how to actualy incorporate that and the players levels.
      It sure would be nice to have the digital input for this stuff.
      Rick
      • rickp
        • Jul 2003
        • 7
        Well. Still the same situation. Doing the channel levels alone I still cannot get the fronts to do their test tone without the rear of the same side, and I cannot get the rear to go by itself. I do have sub and center ok.
        Seperately, the multi channel cables I did check and all is tight. If I am getting a signal to all speakers at some point in time, then it must not be a connection but a setting. Right?
        I suspect there must be some easily missed setting that is causing this but I am stumped so far. Back to the manual again. Is there anyone in particular at Integ Res. to call or a particvular phone number?
        Rick
        • Burke Strickland
          • Sep 2001
          • 3159
          If the six cables from your DVD player are connected to the correct color-coded jacks on the multichannel adaptor, then the problem you are describing (where the surrounds play in unison with the front speaker on the same side) is most likely either a setting inadvertantly out of whack somewhere along the line or a defective multichannel adaptor (with "wires crossed" or whatever). If your dealer or someone you know has one you could borrow for a test, that would be a good way to narrow it down before contacting Integra Research.
          To contact Integra Research for support, you can ask questions by submitting a feedback form on their site at http://www.integraresearch.com/contact_form.cfm and expect to wait at least a couple of days for a response. The feedback form is most effective for general queries, so they will probably not be real helpful with an elusive problem requiring trouble shooting via that mechanism.
          Or call their toll free number, 1-800-225-1946 and tell them you need product support for the RDC-7. As far as asking for anyone in particular, frankly, in my experience, it has been hit-or-miss -- someone who might be helpful one time could well give you the brush off (polite, but lacking any real helpfulness) the next time you get in touch with them. So you might as well give the generic number a call and hope that the person they connect you with 1) is having a good day and 2) knows enough about the product to be able to help you trouble shoot.
          In the mean time, perhaps some of our other members might have some suggestions regarding your multichannel situation? Please feel free to chime in here...
          Good luck -
          Burke
          • rickp
            • Jul 2003
            • 7
            Burke,
            Leslie, on Feb 2 of '02' posted with the same problem. Its the third page of this forum. Seems she got it resolved but didn't know how or what someone did. I may try to reach her and/or call Integra.
            Rick
            • Burke Strickland
              Anybody using the multichannel input instead of "direct" for analog sources?
              by Burke Strickland
              I just got an email from someone who shall remain anonymous unless he volunteers to come forward and identify himself. :>) Actually he asked a good question that I thought might be of general interest, so I’m posting the answer here in addition to answering the email.
              He wants to...
              17 July 2004, 02:38 Saturday
            • jrlaw10
              Dolby TrueHD/RSP-1068/Multi Input Help!!
              by jrlaw10
              Help needed for a novice please!! I have had my RSP-1068 for a year and love it. I have been using a standard DVD player and have connected my audio via a coaxial cable. I have a 5.1 speaker setup. Setup was easy: Video Input 1 is my DVD player with the input as coaxial 1. The default mode is Dolby...
              05 April 2008, 14:33 Saturday
            • DrBoom
              Shootout : Parasound C2 vs Rotel 1098 (long)
              by DrBoom
              Well, it's been almost 2 months now that I've lived with both my Rotel RSP1098 and my Parasound C2 and the time for deciding which I'm going to keep is almost at hand.(not that I HAVE to decide now for some reason, but I'd hate to end up with 2 processors permanently)
              I actually own both of them,...
              20 July 2004, 16:16 Tuesday
              Widescreen Review Magazine article on Sony HS-10
              For those who were asking, here's a "hard" copy of the review. This PJ is one that I've been looking at for a while, and finding good stuff.
              Sony VPL-HS10 Video Projector
              Champagne Video On A Lemonade Budget
              By Greg Rogers
              29 January 2003, 05:14 Wednesday
            • Mike Hayes
              DVDA/SACD Connections to 1066
              by Mike Hayes
              I am considering purchasing a Pioneer 563A ($180) universal player to replace my Toshiba SD5700. I am currently using just the digital connection (not using the 5 analog cables for DVDA). This will be my first experience with DVDA/SACD in conjunction with my 1066 so please bear with me.
              03 August 2003, 09:53 Sunday
