dvd 995 problems
  • jay69
    • Oct 2004
    dvd 995 problems
    i hope someboby can help:
    i have recently tried to play a copy dvd in my player.
    as soon as it loaded it went crazy.
    the unit will not play any normal dvds.
    the message region code error occurs on screen.
    i have tried to reset the unit by holding down play and open while switching power on and pressing vss button. this did not work if there is anybody out their that can help i would be most grateful.
    thanks jay
  • Kevin P
    • 10812
    Welcome to HTGuide Jay. FYI, you accidentally posted as a reply to an unrelated thread (you clicked reply while viewing a thread instead of clicking new thread), so I split your post off and made it its own thread.
    Carry on guys... back to the topic at hand, may I suggest unplugging the player for a few minutes and see if that helps?
    • jay69
      • Oct 2004
      tried that still did not work thanks anyway......
      • braxus
        Upgrade to RC 1590 Preamp or stick with RC 995?
        by braxus
        I currently use the RC 995 preamp. Its a very musical preamp that doesn't lack a lot compared to high end preamps I've heard. But I'm wondering about upgrading to the RC 1590. Any comments on the 1590? Is it too very musical or does it lack compared to their older preamps like my 995? I need tape inputs...
        14 April 2018, 23:46 Saturday
      • dmcgowan
        HELP - RDV-995 / RSX-1055 Component Video
        by dmcgowan
        I lashed out today and brought home a 42" Plasma
        Rearrange the room, new cables connected, etc etc and everything works fine except for using the RSX-1055 to switch component video from the RDV-995.
        I can direct connect the RDV-995 to the Plasma and get...
        25 October 2005, 08:43 Tuesday
      • Bluespower
        RC-995 » What a Nice Pre-Amp
        by Bluespower
        I just got finished installing an early Christmas present to myself, an RC-995. I have this mated with an RB-981, RDP-980, Philips CD player, Thorens TD160, Teac 4300, and B&W 602 S3s. All I can say is that I'm absolutely delighted! This is my office system where I go to mainly pull out the...
        16 December 2007, 20:06 Sunday
      • TaiChiFrank
        Rotel RDV-995 Help!
        by TaiChiFrank
        I have moved from New York, USA to Taipei, Taiwan. The region code on my RDV-995 is 1. I need to change it to 3. Does anyone know the programming to set this unit to Region 3? Is it possible to reset back to 1 for USA DVD playing? A HiTech audio dealer said it can be made to Region 0, to solve my problems....
        21 November 2005, 22:36 Monday
        How loud do you play your B&Ws
        by Briz vegas
        I noticed on the equipement thread that some people were saying they have to play their B&Ws loud for them to sound good (to be complete I should say that more powerful amps seemed to resolve this). Is the volume performance relationship a characteristic of B&W in your experience?
        27 August 2008, 05:58 Wednesday
