Rotel RDV-995 Help!
  • TaiChiFrank
    Rotel RDV-995 Help!
    I have moved from New York, USA to Taipei, Taiwan. The region code on my RDV-995 is 1. I need to change it to 3. Does anyone know the programming to set this unit to Region 3? Is it possible to reset back to 1 for USA DVD playing? A HiTech audio dealer said it can be made to Region 0, to solve my problems. Does any forum members know how to do this?
    TaiChiFrank in Taipei!
  • Marlboroman
    • Aug 2005
    • 73
    You need a special adapter that allows you to connect your computer to a 2 pin jack inside of the RDV-995. You also need a special program from Rotel that connects to the 995 and then allows you to change the region. As far as I know it can only be done by the Rotel service center in Mass.
    • eelco74
      • Dec 2002
      • 394
      It can be done, since European versions were all code free.
      You need to find a tech support or call the disctibutor and see what he can do for you.
      Marantz AV8802, Marantz UD8002, Rotel RB-991 and RB985mkii, Rotel RD960
      Focal/Jmlab Electra 1028S, Electra CC, Electra SW1000S, Cobalt 705
      Pioneer KRL-37V, Epson EH-TW8100, Kinkping CES-180 77"inch
      • nmit5903
        Region code error on RDV 1050 E
        by nmit5903
        I have had region code error problems since buying an RDV 1050 E 2 years ago. As time passes the equipment seems able to read less and less of the DVD's that we buy. Can anyone help please in to reprogram the equipment to read any region code DVD.
        09 February 2008, 02:19 Saturday
      • saurabh
        PAL vs. NTSC DVDs in region free player
        by saurabh
        hmmm... my previous thread has led me to another question.......I know you cant play Region 1 DVD's in Region 4 or others but I also know that you have regionfree DVD players....or you can tweak your DVD's to be region free.......but the real question coming to my mind is :
        Can you play...
        06 May 2005, 06:47 Friday
      • venturi
        1060 region code
        by venturi
        Since there is no law against this.
        How do I add regions or open it up wide to 'all' on my region 1 DVD 1060????
        Rotel has 'all' enabled dvd players in other countries. I asked tech support (rotel)and they said that even though there is no law against selling region free...
        05 January 2005, 18:25 Wednesday
      • todd666
        region free cdp-300
        by todd666
        Can you make any cdp-300 region free with a code and if so whats the code? Thanks Todd
        10 August 2011, 05:03 Wednesday
      • nixonisking
        RDV995 audio mods???
        by nixonisking
        Love my rdv995 as a dvd player, but it also doubles as my cdp. are their any mods or upgrades that I can do to enhance the sound stage when playing 2 channel or just straight pcm??? also using audioquest cables, and revel m20 speakers., any help/., kevin
        11 November 2003, 11:02 Tuesday
