1098 max volume
  • egaither
    • Apr 2004
    • 38
    1098 max volume
    I just purchased a 1090 to use for my mains (RF-7s) to go with my 1095 and 1098. I would like to limit my volume control but am not sure what I should set it to. On my yamaha rx-v1400 I could use a formula to calculate how many watts I was sending to my speakers based on the number presented on the screen. Any idea what the 0-100 numbers represent for volume control on the 1098? I purchased the amp because of the dampening and control not really to send 380W continuously to my speakers.
  • Bam!
    • Jan 2004
    • 2458
    WOW great question......if there is an answer.....can I have the same for the 1056 ?
    Got a nice rack to show me ?
      • 16478
      Calculating wattage isn't really going to do you any good anyway since it will depend on a number of factors ranging from the sensetivity of your speakers, room acoustics, distance to the speakers, amp gain, speaker wire length and guage, and a host of other factors. If you like I'd simply turn up the volume to the max you'd ever listen to the system and set it to that level...chances are it will still be a pretty safe level unless you're hard of hearing or just plain crazy Your speakers will very likely be just fine with receiving what ever current the amps can generate as it will only be a momentary spike and will be a clean sine wave...a low powered amp pushed to clipping will cause serious damage though even though the volume levels may not be as loud as with the more powerful amplifer. Also for what its worth a typical speaker rated around 88dB/1 watt is typically getting under 15 watts even most of the time even during fairly loud passages...its only the huge explosions or canon fire in the 1812 overture that will cause your amp to provide more then that.
      • egaither
        • Apr 2004
        • 38
        I kind of figured this would be the response I would receive. It would be just nice to know. Am I crazy:twisted:...sometimes I can hardly contain myself and I'll crank it up to 80 but that is pretty much as high as I have gone. This is with my 1095. Shouldn't be much different with the 1090—can't wait for it to get here.
        Running the test tones with all speakers set to 75db...volume level is 66. Current speaker configuration is RF-7s(102db sensitivity), RS-7s and RC-7 (all 98db sensitivity). Room is a great room roughly 13x24'. Listening position is roughly 9' away.
        • Aussie Geoff
          RSP 1098 Wish List V2.0
          by Aussie Geoff
        • MustangJeff
          RSX-1056 Volume control issue
          by MustangJeff
          Strange problem that started happening in the past 6 months. The volume control on the front of my RSX-1056 seems to have a mind of it's own.
          When I increase the volume it works correctly, and the numbers (dB) increase normally.
          When I turn the knob counter clockwise to...
          09 October 2012, 14:39 Tuesday
        • Stevebez
          RSP-1066 - changing volume on its own?
          by Stevebez
          I have a Panasonic TH32PWD5 Plasma display, which I understand emits substantial IR radiation which on occasion crosses with the IR frequency used to adjust the RSP's volume!! So on a few occasions I have noted the RSP's volume changing "on its own" to max on one occasion and to zero on two...
          08 October 2003, 08:32 Wednesday
        • Aussie Geoff
          Rotel RSP 1098 Wish List V1.0
          by Aussie Geoff
          As a long time lurker and “newbe” member of this forum I thought I’d start a service of managing a list of suggested upgrades to the RSP 1098. Thanks to all the helpful advice from this forum I have my order in for a 1098 of my own (waiting on the DTS-ES issue being fixed).
          18 October 2003, 09:40 Saturday
        • rosros
          Upgrading;Differences 1066/1068/1098
          by rosros
          The Rotel web site is updated to include the 1066 replacement, the 1068. They also have the 1068 manual online. Having both 1098 and 1066 inhouse (wished the 1068 was here), I compared features, sound and the manuals for the 1098 to the 1068 to the 1066; here are the differences: Note I own the 1066...
          22 February 2004, 23:31 Sunday
