diference between rotel RSP 1068-1098?Help!
  • dixon
    • 21
    I just want to buy a processor RSP 1068 and I wish to known witch is the diference between 1068-1098.I notice some guys on videogon/audiogon sell 1098 around $2000,so is $ 200 more then1068 brand new,or $ 600 for used.I have an Rotel RMB 1075 and Denon avr 3803 right now and I used Denon like a preamp/pro.So I want to known if really the 1098 worth the money.Any advice is welcome.
    Dixon,junior member
    • 16478
    There are other differences between the two other then just the TFT screen but from what several members have reported the difference in sound isn't huge so you'll need to listen to both on the same system to really see if the differences are worth the extra cost to you. I will say that I know several people that weren't sure about their 1098 purchases but so far all of them are deeply in love with it now
    • Aussie Geoff
      • Oct 2003
      • 1914
      Dixon,
      Just to add to what Andrew has posted. The RSP-1098 has the same basic DSP chip and software as the RSP-1068, however there are many differences other than the TFT, such as:
      • Three separate torriodal transformers and power suppliers, one for Analogue Adion, one for Digital Audio and one for Video.
      • Improved Op Am circutry for the front channels
      • Higher quality components (e.g. capacitors and A/D etc in a number of key places)
      All that asside - with the right source and system, it sounds better - but not the 80% better matching the 80% price. So listen and let your ears be the judge... You will know what works for you. Those that have done so on this forum have then been very happy with their choice of RSP-1098 or RSP-1068.
      Geoff
      • dixon
        • 21
        Thanks,Andrew for your input.I'm not sure right now if I will buy RSP 1068 or 1098,anyway I thing is worth 1098 for extra $200, even if is used.Ether way I think I can't go wrong.
        Can anybody suggest some good speakers to mach Rotel amp?([/U]in special for stereo,main speaker)
        My system right now is:
        rotel RMB 1075,denon avr 3803,denon dcd ar 1650,denon dvd 2900,yamaha speaker(NS 555 main)yamaha NS 444 center and yamaha 333 four surround,velodyne 1200 spl II sub.
        Yamaha is ok,sound good and is worth the money,but I think I can find a better one.Can you suggest some brands?
        Thanks again,
        Dixon
          • 16478
          For $200 I'd say its a no brainer get the 1098:T
          Dixon where are you located and what's your budget?
          Generally Paradigm, Energy, B&W, Misson, Martin Logan, Magnepan, PSB, Polk, Onix Rockets and a variety of other brands all make very nice speakers. The typical rule of thumb with speakers is that if the company also makes electronics (denon, Yamaha, Sony etc) there speakers tend not to be that good (there are exceptions but not normally)
          • dixon
            • 21
            I live in Seattle for almost 4 years.I was born in Roumania.
            I apologies for my english.
            My budget for speaker will be about $ 3000.My priority will be first to aquire a processor and second the speakers after I will come back from vacation
            If would like to know your opinion about NS 555 yamaha speakers(give them a try).I bought them from "Best BUY",I am not sure they have also stores in Canada.
              • 16478
              Dixon those speakers look ok but really $249 isn't a lot to pay for tower speakers so I'd guess they didn't use quality components to build them...but without hearing them I don't want to say to much bad about them Still I think its pretty fair to say with a $3K budget you're going to looking at speakers in a whole other league from what you have now. My suggestion is to spend some time looking and listening to as many brands as you can with CD's that you're familar with and enjoy listening too.
              PS your english is great I'd never have guessed your native language wasn't english and we do have Best Buy up here (though I don't buy hi-fi gear there!)
              • jimmyp58
                • 1449
                I'd take a look at some Definitive Technology speakers. They'd be awesome in your setup and will fit your budget nicely.
                Here's an initial suggestion:
                BP7006 for fronts (incredible speakers with built-in power sub) - $600 each
                CLR 2300 for center (awesome with built-in power sub) - $600
                BPX for surrounds (very nice surround speaker) - $450 each
                This brings you to $2,700 MSRP. You'll be blown away. I have a very similar setup in my 2nd HT and it is awesome. If you want an external sub, and I'd suggest doing so, you could get the SuperCube II for $900. This would bring your total spend to $3,600 full MSRP but you might find a dealer to knock 10-20% off. If so, you'd be right around your budget.
                Magnolia Audio & Video in Seattle carries these speakers. If nothing else before you buy anything, go take a listen (but have your checkbook handy as I know you won't leave the store without buying them.
                Ask more questions if need be.
                Good luck....
                jpiscitello@ameritech.net
                • jimmyp58
                  • 1449
                  I just sent you a private e-mail; I'll send you a PM too.
                  • GSamF
                    • Mar 2004
                    • 36
                    Hey Jim,
                    I'm from Seattle as well and since you are buying Rotel gear, I am assuming you are going to Definitive Audio in Seattle since they are the only dealer.
                    If you do have a budget of around $3k, I would suggest b&w speakers. You can listen to them at definitive with your rotel gear, and if it matters, the rotel website has b&w speakers pictured with their rotel gear. I found them to be a great match with my 804's.
                    good luck.
                    Sam
                    btw, everyone here would agree you have to hear for yourself if you like the combo/sound of the gear you have, so I think it is pretty important either to demo at home or listen to the combined gear in the store (although sound may differ once in your home).
                    • jimmyp58
                      • 1449
                      Sam:
                      Actually it is Dixon that lives in Seattle and is looking for advice on speakers with a $3,000 budget and whether he should spend a couple of hundred dollars more for a used 1098 vs. a new 1068. I'd agree though that B&W makes some darn good speakers but more importantly, it is one's ears that tell the truth as to what is most satisfying.
                      While personally, my ears don't enjoy the B&W's as some others do (except for the ASW-600 that I am using as a secondary sub), Dixon should take a listen to them particularly at the dealer you are referencing as they have a Rotel lineup to match with them. By the way, I am not buying Rotel either though I currently own the RSP-1098. That being said though, I'm sure you'd agree with me that getting a complete speaker system for $3,000 with B&W will be challenging; not impossible but very challenging just the same. Great speakers but kind of pricey. He'd have to look at the '600' series to fit into this budget because once he steps into the 'CM' series and beyond (700 & 800 --- you'd know this as your 804's alone are roughly $3,000!), it will be very tough to squeeze all this in.
                      Thanks for thinking of me though and giving Dixon another option....
                        Twin Moderator Emeritus
                        • 16706
                        There's lot's of great speaker options that mate well with Rotel, all different and the only way to tell if you like them is to go listen. This thread is getting a bit off-topic (and non-Rotel related :lol: ) though so Dixon, if you'd like to some more advice on speaker lines I'd suggest first, browing through the Home Theatre section as there have been numerous, similar threads that would be quite helpful :T Second, if you have any other questions etc, start a new thread on speakers in the HT area You'll likely get more/better responses.
                        Here's a couple threads with similar questions and price ranges:
                        • drums76
                          Rotel 1068
                          Can I have some ones opinion on Def Tech Speakers with the Rotel 1068. I have the Def Tech 7001 sc, 2300, mythos on the side and super gems in the rear. I was thinking about buying the rotel 1068. Help!!!!!!!!!!!!!!!!!!
                          • imbeaujp
                            • Nov 2007
                            • 79
                            Hello, If you have a chance, try the YAMAHA NS-1000 with your Rotel.
                            Jean-Pierre Imbeau
                            ROTEL: RSP-1098|RT-1080|RCD-1072|RDV-1060|RLC-1040|RB-1080x2|RMB-1075
                            PIONEER: ELITE PRO-940HD|BDP-HD1|inno
                            YAMAHA: NS-1000|NS-1000M|CA-1010|CT-1000|TC-1000|YP-1000
                            PEARLESS: XXLS-12x4|BEHRINGER DSP-1124
                            • wirebrat
                              • 7
                              In my experience, there is an improvement in audio in the 1098 as compared to the 1068. I've owned both. This unit uses relays instead of IC’s for switching which gives a cleaner circuit path. The 1098 also has three separate power transformers inside, one is a AC filter and then one is designated for the analog portion of the unit and the other is designated for the digital portion. The 1098 uses 4 24/192 CS43122 DACs where the RSP-1068 uses 4 24/192 AK4395VF DACs. Other than that the functionality of the two units are extremely similar (one could argue the same.)
                              For $200 I'd say its worth it.
                              Hope this helps.
                              -- Steve
                              • Bryan
                                Question about the OSD menusystem of the RSP-1068/1098
                                by Bryan
                                I'm blind and would like to know if I could use the OSD menu of the Rotel RSP-1068/1098.
                                I hope you guys can give answers on the following questions:
                                1. When entering the mainmenu, is the cursor always on the first row? Or will it be on the menu item it was when you left...
                                18 June 2004, 15:50 Friday
                              • btully
                                RSP 1098 TFT Stretches 4:3
                                by btully
                                Some of my DVDs are 4:3. However, whatever I do, the 1098's TFT display stretches this material the full width of the display. I do, however, get a proper 4:3 ratio from my monitor when I take the composite signal that is feeding the TFT and use it to feed the monitor. Is this something lacking in...
                                22 May 2004, 20:37 Saturday
                              • Henk
                                RSP 1098 and progressive scan dvd/dvd audio players
                                by Henk
                                The RSP 1098 TFT screen displays no video unless a usable signal is passed through the composite video connection. However, as pointed out in the RSP 1098 manual not all dvd players, set in progressive mode, output a usable composite video signal. This is true also for dvd players that play dvd audio....
                                21 November 2003, 05:55 Friday
                              • gostan
                                RSP 1098 TFT Screen Is Useful
                                by gostan
                                The TFT screen on the 1098 is more than just a pretty face. For the first time I can monitor the various inputs and settings without using my main hd monitor. Also, when I am listening to music I can have the news or weather on the 1098 screen and cut in if I so desire. Anybody else have any thoughts...
                                15 February 2004, 20:48 Sunday
                              • Tom Bombadil
                                RSP=1098 TFT screen quality
                                by Tom Bombadil
                                Hi there,
                                Does anyone have any concerns with the TFT screen on the 1098?
                                Mine appears very patchy with light spill around the edges when blank. and compared to my Samsung 18" TFT it seems excessive. When displaying a picture I don't have any issues with the picture...
                                13 March 2004, 09:31 Saturday
