Need help on problem with RDV1060 and RSP1098
  • Marcel54
    • Jan 2004
    • 60
    I have my configuration since October last year and from the start I have a problem with my RDV1060 and RSP1098 that if correct all users of the SCART connection should have. If the RDV1060 is connected to my TV through the SCART connection and the DVD-player is set on SCART then the TFT on the 1098 only gives black and white (and no colours). I talked about this problem with the distributor in The Netherlands but I don't get through to these people. They say it's a software problem but they don't know if or when it will be addressed. I think it's a bloody shame ( and I'm starting to get very angry) that I still can't use my configuration the way it's supposed to.
    Can anyone of the guys with the connections at Rotel help me (and I think many others).
    Marcel
  • Olaf
    • Nov 2003
    • 57
    Marcel,
    Can you please elaborate on the type of connection between your RDV-1060 and RSP-1098. As the RSP-1098 has no SCART input you must be using something else to get the DVD output on the TFT right?
    Olaf
    • Marcel54
      • Jan 2004
      • 60
      You are right. I forgot to mention that I connected the 1060 to the 1098 through the composite connection (as required). So I connected everything according to the book. My dealer and distributor looked at the problem and they both agree that it is a software problem but I don't have the feeling that Rotel is working (hard) on the issue.
      There is another strange thing and that is that if I put the DVD in component mode I have colour on my TFT but then my TV screen turns green when I play a DVD (and use the pauseknob).
      So I don't need a technical advice because that is clear. I need some entrance to Rotel to get an idea about the willingness to solve this problem. This because the Dutch distributor does't act very cooperative.
      • Olaf
        • Nov 2003
        • 57
        Dear Marcel,
        Just for your information I have exactly the same setup and connection types. I have used software versions 1.4, 1.6, 1.8, 2.1.1 and 2.1.2 with both the SCART and components connections and have not encountered either problem described by you.
        Due to the problems with 2.1.1 I have played around with the software quite a bit as you can see.
        While it is not my place to judge your conclusions or those of your dealer it sounds to me like your DVD player might have a problem.
        Maybe Andrew might be able to refer your case.
        Olaf
        • Lexa
          • Nov 2003
          • 4
          Tv is getting green
          I have the same issue as Marcel and aslo the same connection. TFT is working fine. But if I push pause or stop during playback and then again play, TV picture is getting green. Then I must switch RDV1060 off and play again to have the right picture. Any idea how to solve it?
          • Marcel54
            Problem with RDV 1060 and SCART
            by Marcel54
            I have a complete Rotel set up (RSP1098, RDV1060, RB1080 and RMB1095) and I'm almost completely happy. But I do have a problem. Due to my TV I'm using the SCART connection from my DVD to my TV and there lies the problem. If my DVD is set to SCART my TFT from my RSP1098 is only monochrome (so no colours...
            27 March 2004, 04:21 Saturday
          • >>Angel<<
            RSP1098 TFT display activation.
            by >>Angel<<
            I recently bought the RSP1098 (next to the RMB1075) in combination with the RDV1060, what a nice combination this is . However I do have some issues/questions:
            - How can I enable color on the TFT display when DVD video is passed (via composite video) to the 1098?...
            01 February 2006, 16:05 Wednesday
          • fordster
            RDV1060 DVDA Problem
            by fordster
            I've had my RDV1060 for a few weeks now and finally got round to buying a DVD Audio (Under Rug Swept - Alanis Morrisette). When I insert the disc the player picks up that it is a DVDA and shows 96-24MLP on the display. However, that's about all that happens beyond a bit of clicking. The timer eventually...
            28 March 2005, 14:14 Monday
          • Marcel54
            Connectingproblem RSP1098 and RDV1060
            by Marcel54
            I bought a new DLP TV so I connected my 1060 with component directly to my HD TV set (previously I used SCART). My 1060 is connected to the 1098 with composite for use of the TFT screen. Here's the problem: when I set my 1060 to progressive scan my TFT screen goes haywire (all I see is horizontal disturbance)....
            08 April 2005, 09:22 Friday
          • sirbogey
            progressive on RDV1060
            by sirbogey
            My RDV1060 came back from Rotel with an exchanged tray. When I put in a DVD or CD, it takes like 10 secs for the disc to load. This was a matter of 2-3 secs before. What have they done to it?
            Another question: I changed the picture to watch a movie in progressive mode. When I do that,...
            22 September 2006, 02:58 Friday
