Problem with RDV 1060 and SCART
  • Marcel54
    • Jan 2004
    • 60
    I have a complete Rotel set up (RSP1098, RDV1060, RB1080 and RMB1095) and I'm almost completely happy. But I do have a problem. Due to my TV I'm using the SCART connection from my DVD to my TV and there lies the problem. If my DVD is set to SCART my TFT from my RSP1098 is only monochrome (so no colours anymore). I told this problem to my dealer and distributor in November of last year but untill now the problem isn't solved. Does or did any of you have this problem and if so is it solved?
    Marcel
  • triDave
    • Dec 2003
    • 29
    I also have problem with scart and ROTEL 1060-dvd... When I hit pause, the screen turns green when I press play again... stupid bug...
    Dave
    • Marcel54
      • Jan 2004
      • 60
      Dave,
      I had the same problem, but the dutch Rotel-guys made an upgrade and after downloading that problem was gone. If I were you I contact your dealer and tell them that that bug can be fixed.
      Marcel
      • triDave
        • Dec 2003
        • 29
        Did your drive sound less after the upgrade? One can only hope. I'm currently thinking of building some kinda sealed box for the dvd, since it's terrible loud, more than my projector...
        Thanks for the advice, with the upgrade!
        Dave
        • nvdeynde
          Rotel rdv-1080: Firmware / DTS problem
          by nvdeynde
          When playing DVD's with a DTS soundtrack the picture stutters and jerks. This problem Is not consistant as some DTS disks are ok. and the problem DVD's stutter at random. (when playing the same scene the problem Is there but not In the same place). DD DVD's are OK, I have tried R1 and R2 DVD's.
          01 July 2012, 07:43 Sunday
        • The Lean
          Problem with RDV-1060 when controlled by RS232
          by The Lean
          HI
          I would be very interested to hear if any one who has a RDV-1060 controlled via RS232, are having problems with the unit display and control locking up or all the illumination going out, yet the unit will still work via 232. I have set up some soak tests with my own unit and also a...
          04 January 2005, 04:00 Tuesday
        • dennis123
          subtitle problem on RDV 1060
          by dennis123
          I live in Europe and sometimes I use the subtitles in dutch. Yesterday I also put on the subtitles and I noticed that with some movies the subtitles start to flicker ( I don't know if that is the correct word). It goes rapidly on and off and if I look closely I'll see there are...
          10 January 2005, 04:43 Monday
        • Marcel54
          Need help on problem with RDV1060 and RSP1098
          by Marcel54
          I have my configuration since October last year and from the start I have a problem with my RDV1060 and RSP1098 that if correct all users of the SCART connection should have. If the RDV1060 is connected to my TV through the SCART connection and the DVD-player is set on SCART then the TFT on the 1098...
          14 May 2004, 10:45 Friday
        • nvdeynde
          Rotel RDV 1060: Audio Decoders output,goto & other problems after software upgrade
          by nvdeynde
          My RDV 1060 had firmware 2.0.8 and I know this one has several problems with DVD-Audio discs and progressive scan.
          I assume the latest software available now is 2.1.2
          I have a few questions to owners with that software installed:
          1) How is the...
          26 May 2006, 06:11 Friday
