I plan to connect a CD player from Marantz CD 6003 to the RSP 1069 which is connected to a power amp RMB 1077.
The Specs for the CD 6003 output is listed below.
Would like to know if there is any issue of impedance mismatch with input expectations to the Analong input and the Coaxial inputs of the RSP 1069.
Marantz CD 6003 Specifications
AUDIO CHARACTERISTICS
Channels ... 2 channels
Frequency response ... 2 Hz to 20 kHz
Dynamic range ... 100 dB
Signal-to-noise ratio (A-weighted) ... 110 dB
Channel separation (1 kHz) ... 110 dB
Harmonic distortion (1 kHz) ...0.002%
Wow & flutter ... Precision of quartz
Audio output ... 2.35 V rms, stereo
Headphone output (variable maximum) ... 18 mW/32 ohms
Digital output Coaxial output (pin jack) ...0.5 Vp-p, 75 ohms
Optical output (square optical connector) ...-19 dBm
OPTICAL READOUT SYSTEM
Laser ...AlGaAs semiconductor
Wavelength ... 780 nm
SIGNAL SYSTEM
Sampling frequency ...44.1 kHz
Quantization ...16-bit linear PCM
POWER SUPPLY
Power requirement ... AC 230 V 50/60 Hz
Power consumption ... 19 W
Standby power consumption ... 0.3 W
SIGNAL SYSTEM
POWER SUPPLY
