Hi all - I'm new to this and sure could use some 'expert' help with an issue with my Rotel RSX 1055. When I turn on the receiver, a loud popping sound comes through the speakers. Afterwards, there is no volume heard only a very slight hum. Any ideas?? Thanks!
RSX 1055 "Popping Sound" Issue
I have a similar problem but slightly different. I can hear popping sound when it is turn on, but it still has sound. And the popping sound is intermittent. I took it for a service center, that guy said some welding or wiring is loose. That guy charge me $200.- Bottom
I had a same problem, under warranty, ti was the digital card, they changed it work as a new now...
Also poping into speakers when you turn on could be an electrical problem in your hardline, ground loop...- - - - - - - - - -
"Are you gonna bark all day little doggy?...or are you gonna bite?- Bottom
by lmibHi all of you RSX 1055 and RSX 1056 owners,
i have an interesting problem, for that I cannot find a thread in the forum. I was sure I read something about this, but I'm not quite sure.
My RSX 1055 make a continues popping while changing the volume above 30. Under 25 it...-
Channel: Club Rotel
by thanirsHi all,
I own RSX-1055 and RDV-1060. I have had them for 5+ years now. Both have been consistently unreliable. RSX-1055 broke a couple of times and has been fixed. The CD player also broke once and has been fixed as well.
Last week, when I turned on the RSX-1055, it made...-
Channel: Club Rotel
by Andrew PrattRotel has a FAQ available here that may answer some of your questions. We've added several points of our own as well below.
1. How do I know what firmware is installed on my processor?
Answer: Simply press and hold the mute button on the remote and it will be displayd on the LCD...-
Channel: Club Rotel
15 April 2003, 14:08 Tuesday -
by Tha FreakI have a RSX-1055 and since I installed my HT in my new house, there is often (not everytime) a pop in the speakers when I turn it "ON" from Standby mode...?
It was not the case in the other place (before I moved) ??
Is there a miss conection in my set-up?...-
Channel: Club Rotel
by GlennI have temporarily set-up my new RSX-1055 to make sure all is working correctly. It has the latest firmware.
The current set-up is 2 channel. Just the basics for right now. I went into the set-up menu and changed the front main channels to "large". I set all the rest to "none"....-
Channel: Club Rotel
- Loading...
- No more items.
