Rotel RSX-1056 receiver low video sound?
  • hipertec
    • Jan 2010
    • 6
    Hi, I have RSX-1056 receiver and the tuner sounds loud and wonderful. When I hook up my sat box or PS3, etc in the video section, it is much much lower. I would need to up the volume +20 to get it to about the same as what the tuner was playing.
    Any suggestions?
  • Kevin D
    • 4601
    Typical, especially if you are using the digital inputs for the other two (and you should be).
    The 1058/1550 added source level adjustments to help.
    Kevin D.
    • hipertec
      • Jan 2010
      • 6
      Kevin D.
      Thanks for the response. Yes, I am using the digital inputs (opticals).
      What is the added source level adjustments and where can I find this on the 1056 receiver?
      • Kevin D
        • 4601
        1056 didn't have it. You would have to upgrade to the 1058 and newer to get it.
        Kevin D.
        • hipertec
          • Jan 2010
          • 6
          ya..thanks. Last question, I noticed that if I am using the optical from my Sat box, sometimes I will get a small "pop" or "click" from my speakers.
          Any idea whats causing this? I get worried that it will mess up my speakers.
          • rick c
            • 430
            Thats the exact reason i exchanged my first rsx1056.Cant remember the cause right now.But if you did a search i'm sure you'll find it as others had the same preoblem.
            • hipertec
              • Jan 2010
              • 6
              I wonder if Rotel will repair this issue since it seems to be a reoccurance problem...even when the receiver is an older model?
              • bhauseur
                InFocus 4805 set-up questions, HD receiver suggestions
                by bhauseur
                I am moments away from pulling the trigger on the InFocus 4805. Costco has it with a 75" sceen for $1229.00.
                I want to mount it on my ceiling. I hear the Keystone adjustments are difficult (I thought Keystone was a cheap beer, until yesterday). Also, should I buy the InFocus ceiling...
                08 December 2004, 14:05 Wednesday
              • rick c
                Rotel rsx1056 2ch mode ?
                by rick c
                On my rotel rsx1056 when listening to the tuner if i press 2ch on the remote i will get "bypass" which is fine.When i'm listening to cd's if i do the same 2ch i get "pcm".Now my cd player is connected both digital and analog to the receiver.I'm assuming i get "pcm" because...
                26 April 2005, 20:25 Tuesday
              • rick c
                ? for rsx1056 owners with dvda/sacd players.
                by rick c
                Those of you who have the rsx1056 with a dvd-a/sacd player how did you do the setup in the rsx1056.I understand that settings are done thru the dvda/sacd player but how about the receiver.I was looking at my receiver last nite and i beleive you need to go in the multi setup options but didnt see real...
                29 July 2005, 18:48 Friday
              • FSonicSmith
                RSX1056 Video Switching Card Bandwidth?
                by FSonicSmith
                I'm not happy with the PQ I'm getting from satellite high def. My satellite receiver's output is going into my Rotel via component and is then going out from the Rotel into my front projector via component cable. Someone on another board (AVSforum) suggested that my problem may be my receiver. He contends...
                25 March 2005, 13:54 Friday
              • frank1203
                How Can I Display RSX-1056 Settings on My Plasma?
                by frank1203
                Hello, I am in the process of relocating some of my Rotel and other HT equipment from my Family Room to my basement. The Plasma will remain mounted in the Family Room and all of the HT equipment will be accessed using IR Repeating equipment.
                One of the pieces of equipment I want to move...
                22 October 2006, 19:21 Sunday
