InFocus 4805 set-up questions, HD receiver suggestions
  • bhauseur
    • 3
    I am moments away from pulling the trigger on the InFocus 4805. Costco has it with a 75" sceen for $1229.00.
    I want to mount it on my ceiling. I hear the Keystone adjustments are difficult (I thought Keystone was a cheap beer, until yesterday). Also, should I buy the InFocus ceiling mount kit or is there something out there that is universal and maybe cheaper? Can I build a box? Does it have to angle down or will the Keystone adjustments take care of that issue?
    My other question relates to a HD receiver. As the 4805 doesnt have a tuner I need something to pull stanard cable and I want to receiver OTA HD signals. Any suggestions?
  • Doop
    • 22
    I don't know who told you the keystone adjustments are difficult, because that certainly wasn't my experience. Two buttons, you play with them a little until the image edges are parallel with the screen edges, and you're done. Piece of cake.
    As for the mounts, there are a lot of ceiling mounts out there, some universal and some designed specifically for the 4805. I would suggest doing a search and looking at what's available. Two places to start might be projectormounts.com or perfectmounts.com. I've never seen the products so I can't say whether they're good, bad or indifferent.
    Can't help you with the receiver. I have Dish Network satellite.
    Incidentally, the 4805 is an incredible value. I'm not a professional, but I can't tell much difference between the picture it provides and the ones I see from the really, really expensive units at the dealer. Contrast and color are fabulous. Also, it's very versatile.
    Two shortcomings, neither of them critical.
    1. Infocus uses an M1 connector for its DVI input, so you will almost certainly need an adaptor. The company sells one for $45, and I've seen it for about $10 less from other companies.
    2. Brightness. You really need a fairly dark room. Not pitch-black, but if you can read a newspaper comfortably, you probably aren't going to be terribly pleased with the TV image.
    Enjoy!
    • bhauseur
      • 3
      Thanks for the advice. I pulled the trigger last night and bought the 4805. Two problems. I can't get a video signal from the S-video port and the composite (yellow RCA) connector had a dead short and when I pulled it into my Tivo it sparked!! It killed my Tivo!! My going back to Costco to raise hell. On a positive note my kids watched Sherk on the wall and the picture was amazing.
      • Dean McManis
        • May 2003
        • 762
        Hopefully it was a dud unit, and they will make it up to you. the 4805 is a great bargain!
          • 16172
          CostCo has great return/exchange policies, so that's a good place to pick to buy it.
          The sparking thing could be ESD accumulation when walking around the room. Plug it into an outlet first, and be touch the grounds of your signal cables to the connector shell ground first to be sure there's no voltage potenial difference. I've seen other equipment killed or damaged by ESD before- though not in my home!
          ~Jon
          • davedvf
            ScreenPlay 4805 vs. InFocus x1
            by davedvf
            I purchased the InFocus x1 a couple of years ago along with a portable Da-Lite white 6x8 screen. We use it a couple of times a month (whenever a movie worthy of the extra effort comes along, or when the kids invite their friends over, etc). It has also been a blast to host our...
            22 April 2005, 18:15 Friday
          • JW_in_Philly
            DVD player to match infocus 4805
            by JW_in_Philly
            I'm sure this has been covered ad naseum, but with 30+ pages of posts, it's hard to find. Have a ~5 yr old panasonic rv30 dvd player that works great, but am about to upgrade the Quasar 27" (that's right, Quasar) with an Infocus 4805 projector. I figure I would be wasting my time without having...
            13 January 2005, 15:05 Thursday
          • jerry SS
            InFocus 4805 Just Bought - Have Rolling lines -?
            by jerry SS
            Hi all - I just found this forum, and am so glad I did !
            Great info on here -- I was searching around, and didn't find this particular problem anywhere, so I am posting it - I hope you guys can help.
            I live in PA, and, (like others here I see, ) bought the InFocus 4805...
            09 February 2005, 12:56 Wednesday
          • ti33er
            My new Infocus 4805!
            by ti33er
            Well well well, the UK has finally graced us Brits with the much talked about Infocus 4805!
            I had a demo yesterday afternoon, and without a shadow of a doubt, handed over my plastic wallet within 30 minutes – we did a side-by-side comparison with the Infocus 5700, and I tell you what,...
            01 July 2004, 09:46 Thursday
          • Doop
            Infocus 4805 vs 5000 (DLP v LCD)
            by Doop
            I was fortunate enough to have the use of a new 4805 & 76-inch Infocus screen for a couple of weeks. I'm planning to buy a projector and screen in mid-February.
            (Incidentally, it will definitely be a step up, no matter what: It's replacing a Kloss Novabeam built around 1982. Works...
            14 December 2004, 12:42 Tuesday
