need help on using rotel rsx-1056
  • tdt00
    • 6
    Hi all,
    I just bought a used rotel 1056 and I need help setting up the unit. I'm currently running a coaxial from a dvd player to the unit for sound, the video cable go directly to the tv. What I'm trying to do is to set-up the speaker level and cross-over, but I can't seem to get to it. I have never used rotel products before. I'm reading the manual for the remote rr-1050 and rsx-1056, but no luck. Please help me. Thank you.
  • Kevin D
    • 4601
    You will need to connect some type of video cable from the 1056 to your TV. The setup menu is on TV screen only.
    Kevin D.
    • tdt00
      • 6
      Hi Kevin,
      I connected the video signal of the DVD Player to Composite In-2 and the Coaxial-Output to Digital-Input(Coax-1); no sound would come out if I use Coaxial-Input2 or 3 of the rotel. The Composite Out-2 runs to the TV. And there seems to be no picture if I use Composite In-1; Comp In-2 seem to be the only input that have picture.
      I'm starting to question if this unit is messed up.
      Thanks for all your time and help, Kevin.
      • Kevin D
        • 4601
        You can choose which video input and which digital audio input each input uses. You need to connect the TV to MONITOR OUT in order to see the setup menu..
        Kevin D.
        • tempest
          Newbie needs help - Rotel quality driving me nuts
          by tempest
          Hi Folks,
          I'm a newbie hear looking for some help and encauragement. I purchased a Rotel RSX 1055 receiver just before Christmas. All was fine until about 2 or 3 months ago. One morning after turning on my home theater the front left speaker started popping loudly. To the point where...
          29 May 2004, 12:31 Saturday
        • nadroj29
          PLEASE HELP help Rotel RSP 1098 serious issues!!!!!
          by nadroj29
          If your taking the time to read this please continue I NEED HELP....g
          God im about sick to death of buying expensive electronics and having them go out on me... i previously posted questions regarding my brand new Rotel rsp 1098. Now i came home today and tried to use my also garbage blue ray...
          10 November 2006, 00:42 Friday
        • Alex999
          Please help; Rotel and b&w, not sure what to do
          by Alex999
          Hey guys,
          I just purchased a pair of B&W 805S speakers (they should be delivered in few days). I have a Rotel RMB-1095 amp, Rotel RSP-1066 preamp and RDV-1040 DVD/CD player. When I got my original components I was planning to go 5.1 set up but things changed and I use my system for 2ch stereo...
          05 October 2008, 19:55 Sunday
        • NeilGabriel
          HELP Rotel RSX 1067 screwed it up
          by NeilGabriel
          I got this used, but think I caused the problem. When I set it up, I stupidly plugged the multichannel audio outs from my BR player into the multichannel outs of the receiver instead of the ins.
          When played, the receiver went into max volume that could not be turned down until it hit...
          24 November 2010, 15:31 Wednesday
        • mattstacey
          Rotel 1066 component video setup problem
          by mattstacey
          Hi guys,
          I just replaced my Denon 3802 with a Rotel 1066 yesterday, hooked up to a Rotel 1075 amp. I haven't had much of a chance to listen to it yet but so far it sounds awesome.
          I have a problem with my video connections though. I had no problems with the Denon 3802 so...
          18 October 2003, 23:39 Saturday
