Please help; Rotel and b&w, not sure what to do
  • Alex999
    • 115
    Hey guys,
    I just purchased a pair of B&W 805S speakers (they should be delivered in few days). I have a Rotel RMB-1095 amp, Rotel RSP-1066 preamp and RDV-1040 DVD/CD player. When I got my original components I was planning to go 5.1 set up but things changed and I use my system for 2ch stereo music 95% of the time plus I watch some TV.
    Would I notice any significant difference if I sell my stuff and get a Rotel RB-1080 (or RB-1090) amp with a RC-1090 preamp? I'd like to repalce my RSP-1066 processor with a true stereo preamp but only if it is going to give me better sound (I'm not sure about this tho) and maybe keep my RMB-1095. I'm also planning to get RCD-1072 CD player. Please let me know what you think.
    I'm also open to suggestion regarding replacing my 1066 preamp with a different brand name or a different Rotel stereo amp that will work better with my new speakers. Thanks guys.
    I would definitely suggest changing up the 1066, the 1080 over the 1095... there's some difference, but it's not a HUGE difference. I might suggest looking at the Cambridge Audio 840c over the 1072, it's more...but if you aren't replacing your amp, it's a HUGE increase in sound over the 1072.
    If you can snag a 1090, I'd do it. That amp is a beast!
    • Alex999
      • 115
      Thanks Pewter. I forgot to mention, but I was thinking of getting a Musical Fidelity A5 CD player instead of 1072. It costs more ($1200-$1300 used) but it's supposed to be an amazing CD player. So confusing. I mean I can sell my RBM-1095 for probably more money than RB-1090 or get RB-1080 ($500 used on AGon) and invest extra money towards a good pre amp. However, I'm thinking a good CD player will make the biggest difference.
      As I said, please feel free to make any suggestions. I'm thinking to get a good CD player first (the most important improvement), #2. preamp, #3 amp.
        I heard the Musical Fidelity A5. I think it and the Cambridge are compareable (couldn't listen to both on the same setup). One thing I liked with the Cambridge is the fact that I have both my PC and PS3 routed through it to use the DACs from it. It has made a huge difference in my listening of music off both those sources.
        Might be something to consider if you want a good "dac" for other things than CDs. :T
          Same thing happened to me! I got a used 1066 for HT, and it ended up getting me back into my music. Like you, I am about 90% 2 ch music now.
          I still use the 1066 for TV and HT, and for that, I have no complaints. But it’s not great at resolving musical details in 2 ch. I first added a dedicated 2 ch pre, and that was a V worthwhile improvement. I then upgraded my CDp, and again, a noticeable improvement was made. I now have a CA 640C v2, (PewterTA’s old unit) and it is a wonderful sounding player.
          • Alex999
            • 115
            Thanks Pewter and Wkhanna. I think I'll go ahead and get a Rotel 1072 as it's in within my price range. I don't think I can afford anything more at the moment. I think that a good CD player is more critical at this point than my preamp. I need to save some more money before I replace my RSP-1066.
            I'll probably test everything when I get my new speakers. My next step will be to replace my preamp. I'll probably sell my 1066.
            Whkana, how do you use 2 preamps with your amp? Sorry if it's a stupid question. I just had a long day at work, so tired .
              For TV/HT his 1066 routes the L & R channels through his Carver Pre out to his speakers.
              I would highly recommend saving the money up for either the Music Fidelity or Cambridge Audio CDPs... It's more worthwhile to put the money into one of those CDPs over doing anything with your Pre.
              Only reason I would say to get the 1072 is if you plan on selling it later to recoup a little bit of money...but if it was me, I'd just save up for the better CDPs. Course that's just me with having finally made it to the "top" level. I wish I had just bit the bullet originally and gotten the CA 840c. Would've saved me money in the long run.
              • Alex999
                • 115
                there is a new CA 840C on Audiogon $1150. Tempting . How would you describe the difference between Rotel 1072 and Cambridge Audio CA 840C? I'm not sure if I can audition it in Calgary.
                  First let me say that the 1072 is a great CDP. If you never hear something better than it, you'll be completely happy with it and it CAN be an ending point for a good source. On the flip side though, I think for a little bit more money you can get a lot more if willing to spend the money.
                  Uhmm... Basically it's a pretty big difference. The 840c actually has BASS to the CD, due to the dual Anagram DACs in a differential setup. This is basically the biggest (night & day) difference. I'd say the CA also does a much better job of imagine with rock solid location on all instruments. I also think it definitely reveals a whole new level of detail that the 1072 does not. The 1072 (in my opinion) was very very close to the CA 640c V2 so it's more on a level with that (but at a higher price). So for not a whole lot more, you can get (again in my opinion) the best CDP under about $4 or $5K.
                  The nice thing is that wkhanna has formed all his own opinions after hearing the units for himself... so we are both hearing the same things in our systems.
                  The CA 840c is definitely the last CDP I'll buy (unless I gain millions and billions of $$$) lol. Which I don't see that ever happening.
                  • Alex999
                    • 115
                    Thanks Pewter. I'm enjoying my new speakers right now. They are wonderful even with my older preamp, old monster cables etc. I can afford to purchase a Rotel RCD-1072 now but it seems to me that CA 840C is a superior player. I need to go to Edmonton to audition it (I know I can order it on-line and return it but I'm not sure I want to go that route ops: ).
                    I'm going to let my new babies break in and think about my next move. I definitely want to replace my RDV-1040 next plus get some better cables and interconnects.
                    Another thought is to get a good DAC. OK, I should stop now. I need to learn more about DAC stuff as I'm not very familiar with it. Some people suggested that a new good DAC will make a bigger difference than another CD player. On the other hand, 840C has an internal DAC built in ...
                      Built in and will accept 2 external sources that it will put through it's 2 anagram DACs... :T
                      Definitely, if you can, go audition it and see what it's like. Though I think once you hear it, you'll want it (especially if they have it set up properly)!
                        Dan got his 840 from the Audio Shed, an advertiser and big supporter of the forum here (look in the right hand corner at the very bottom of the page). Might want to give them a PM for some more info.
                        I've listened to Dan's 840. Nothing comes close at even three times the cost compared to anything i've ever heard. AIMHO, as always
                        • tboooe
                          Halo A21 vs Rotel 1080: Initial Impressions
                          by tboooe
                          Falling prey to upgraditis and all of the great things I have heard about Parasound I went ahead and got the P3 preamp and A21 to audtion in my home. ASIDE: if anyone wants an in home audition and your local dealer wont do it, contact Paul Brownlee at Parasound (paul@parasound.com). I contacted him...
                          11 August 2005, 21:47 Thursday
                        • Nick M
                          Thiel & Krell
                          by Nick M
                          I spent about four hours at my local hifi shop yesterday listening to various combinations of gear from Paradigm (Signature Line), Thiel, Rotel, and Krell.
                          After listening to my Signature S4's at home for many hours I have picked up on a couple things I would like to improve upon with...
                          18 January 2007, 11:30 Thursday
                        • RotelGuy
                          Rotel to McIntosh
                          by RotelGuy
                          Hi, I have some Rotel equipment and been very happy with them. I always like the meters and lights and build quality of the McIntosh looks. I've read forums where people say that McIntosh is out of Rotel's leauge and McIntosh is far better and superior. This sent me down a path of really wanting...
                          24 April 2008, 15:33 Thursday
                        • =AirCeej=
                          A View into the Rotel 15 Series Class D Amps
                          by =AirCeej=
                          During the process of putting another HT together, I began auditioning amps to replace a Sunfire Series 1 Load Invariant and an Anthem MCA20 – noteworthy at the respective price points in their day and for the Sunfire: novel. Appreciating the ideas and most of the execution designed into the Sunfire,...
                          04 April 2009, 09:23 Saturday
                        • Pez
                          Hearing is believing with 1072
                          by Pez
                          My friend was looking at CD players so when I went to an A/V shop he tagged along to see whats out there. I had mentioned all the good things I hear about the Rotel 1072 but he wanted to spend a fraction of what it costs. The salesguy proceeded to hook up a few players from Rotel, NAD, Cambridge Audio,...
                          15 August 2005, 20:16 Monday
