Firmware upgrade cable question
  • Rotelligence
    • 28
    i have read through the FAQ(great job to everyone who put those together).
    my problem is with Rotel. I have called several times trying to order a cable and they keep telling me all service reps are busy, please leave # and someone will get back to you. So far they have not
    Does anyone have an extra firmware cable I can buy from you? I'll pay premium for it.
    I need to get my 1066 upgraded.
  • Stage1
    • 23
    Firmware Cable
    Hey Rotelligence, I don't know what number you called but I just ordered one from Rotel on Friday. The phone number I called is 1 800-370-3740.The cost is 4.05 plus 10.00 UPS shipping or 3.00 US mail. Had no problem ordering. Good Luck, hope this helps.
    • Rotelligence
      • 28
      thanks. i'll try that # ;x(
      • Rotelligence
        • 28
        the # worked. i got through.
        thanks
        • Stage1
          • 23
          thanks
          Your Welcome, thats why we're all here.
            Props go out to Rotel for their Firmware Updates!
            by PewterTA
            I just thought I'd start a thread to say how HAPPY I am with the Firmware Updates!!! :T :T
            I just updated my 1098 from 3.1.0 to 3.1.4 and WOW. Every issue I had with the unit has been fixed! No DPLIIx - Game mode, now have it. No sleep mode for TFT, now have it. DTS drop out with...
            23 February 2005, 23:13 Wednesday
            new firmware!
            by Andrew Pratt
            There's a new firmware available for the 1055 and 1066. You can find the two versions of the files here on my site. Please remember that the version 1.50 is only for the first generation models. If you're not 100 percent sure which you have press and hold mute till your current firmware is displayed...
            05 August 2003, 09:47 Tuesday
          • chamath
            Rotel Firmware update -- info
            by chamath
            I would like to share my 2nd upgrade experience with you so hopefully you would not run into the same issues I had. I have a Rotel RSX-1057; however, the issue described below would apply to any upgrade as it was not a Rotel problem.
            Firmware: (1057)
            my system = 2.1.2
            03 December 2007, 15:04 Monday
          • shane2468
            Quad 405
            by shane2468
            What speakers are suitable for the Quad 405 poweramp?
            29 April 2009, 14:52 Wednesday
            Introducing: Cable Synergy and...
            by Lex
            Hello all, well, I have went off the deep end, officially... I just started a new cable based web site called:
            http://www.cablesynergy.com
            The name is fairly self evident, but there's more to it than that. There's also a DIY "getting started" for making cables,...
            05 July 2002, 20:26 Friday
