2nd Sub when running Bypass
  • Nolan B
    • 1792
    At the moment I have my Toshiba HD A1 connected via the analog inputs on the 1068 for Dolby Digital Plus and True HD. Does anyone know if the Sub 2 can work in addition to the Sub 1 when running in bypass mode with a 1068?
  • Kal Rubinson
    • 2109
    Dunno but a Y-connector would.
    Kal
    Kal Rubinson
    "Music in the Round"
    • Blindamood
      • Sep 2003
      • 900
      The following is from the manual:
      "Both SUB outputs provide the same signal. Use either connnection for a single subwoofer. Use both connections to hook up two subwoofers."
      Brad
      • chinets
        • 855
        Back of 1068 ,I believe, should as I have for the In my 1098 for HT have 2 sub Inputs ,so that should work In bypass mode too just like your 1 st Sub.
        If you don't have 2 Inputs ,then you can daisy the conecction, and Sub 1 will be the Main command.
        Hope that helps!!!
        I have 2 subs ASW 850, and connected in 2 different Sub Inputs In 1098, and In Bypass mode It is Sensational!!!
        Good Luck and keep us posted!
        Cheers
        • landshark99
          RSX-1057 and losing sub
          by landshark99
          I keep losing the sub output when i have RCA coming in from my ipod or other source. Everything else plays fine, i just lose the subwoofer.
          The only way around it is to go into the 1057's menu and reset to factory. Anyone have a clue why this is happening? All the other sources are fine,...
          14 June 2007, 18:10 Thursday
        • Minivan
          Rotel 1056 analog bypass question
          by Minivan
          Easy folks,
          just upgraded from RA-1062 to a HT setup with a RSX-1056. I haven't quite tweaked it to perfection yet. I'm running Monitor Audio GR10's and Rel Q201E sub. Haven't hooked up the rest of the speakers yet, but got some B&W's 601's for rears.
          Anyway, 2 channel...
          02 August 2006, 03:56 Wednesday
        • methril
          RSX-1067 Zone Channels as Sub Amp for Gallo Ref3's?
          by methril
          I'm having a tough time finding a quality crossover to filter the full range line-level signal from my receiver's pre-outs prior to running them through a separate 2-channel amp (NAD C370) to power the 2nd set of subwoofer voice coils on my Gallo Reference 3's. Guess I'll just have to wait for the Gallo...
          06 July 2005, 01:29 Wednesday
        • Prost1986
          1068 Sub hookup
          by Prost1986
          Good day all…
          Currently I have a velodyne SPL10 sub hooked to the sub out on my 1068 which is only used for movies. I would like to also be able to use the sub in 2ch bypass. After my SACD/DVD STB I hooked my cd player up the multi channel inputs and turned the LF redirect on and was...
          06 December 2006, 14:17 Wednesday
        • Sonnie Parker
          Help design the new Behringer Sub Equalizer BSE2496C to replace the BFD...
          by Sonnie Parker
          I have spoken with Behringer and they have shown serious interest in designing a replacement for the BFD that is more suited to the consumer market. As many of you may already know... the DSP1124 has been discontinued. The replacement FBQ2496 only offers 1 preset and still doesn't get us many of the...
          07 February 2006, 15:58 Tuesday
