Rotel RSP1066 wont switch on via remote, also losing settings?
  • KrisKeen
    • 38
    hi Guys
    my much cared for Rotel rsp1066 which gets minimal use now wont switch on via the ON button on the supplied remote, I need to switch it on manually. Further when I update the OSD with Input names and switch the unit off, the names disappear. This never used to happen..
    Any ideas? Should I take it into my dealer?
    thanks
  • Danbry39
    • Sep 2002
    • 1584
    Kris,
    Kind of a stab in the dark, so please forgive my fading memory if it is.
    I used to own the same pre/pro, but that was a few years back and I might be confusing it with another piece of gear. But, if not, can the 1066 be put in sleep mode as well as on/off. If so, the remote control might only work on either putting it in and out of sleep mode or on and off. You might want to try putting it on sleep on the main unit, then seeing if the remote works to get it in and out of sleep. If that doesn't work, try turning it on at the main unit and seeing if the remote turns it on and off.
    As I said, I might well be mixing it up with another unit I owned, but, at least on one of them, the remote was limited in this fashion.
    Keith
    • KrisKeen
      • 38
      Hi Keith,
      Thanks for the reply. It does have a sleep mode, but they call it standby. The amp/processor contuinally gets power but the red standby light on both the 1075 and 1066 goes on. Then, usually, I press ON using the remote and it switches the 1066 on and then using the 12V trigger Ive always used, switches on the 1075 Amp also.
      This no longer works, basically I need to physically press the 1066 power button off, then on to trigger it all on.
      Further to this, the 1066 has now just started losing its Input labels and so on, very strange.
      • Danbry39
        • Sep 2002
        • 1584
        Sorry it didn't work, Kris.
        Well, hopefully someone more in the know will chime in.
        If not, you might try giving Rotel a call. They've been pretty helpful to me in the past.
        Keith
        • KrisKeen
          • 38
          Well, stupid me! I've replaced the batteries in the remote and its all working
          The remote chews batteries VERY often
            Another case of the simplest answer being the correct one!
            As recent owner of a 1066, I can attest to the remote using up normal batteries quickly. In the 9 months I've had mine, I'm on my third set.
            Actually, I'm going to get a set of rechargeables, same as I use in my digital cam.
            Just glad you got it figured out!
            • KrisKeen
              • 38
              DOH! I spoke to soon
              Again, the ON button and now just about all buttons are failing. Strange thing is, the green back light remote is working fine so theres power - I suspect my Remote my be faulty.
              Anyone know the warranty period on the 1066?
              Thanks!
              • Kevin D
                • 4601
                5 years if you are the original buyer, but contact Rotel and they will usually help you out.
                Kevin D.
                • Basil
                  CP-800 Remote stopped working?
                  by Basil
                  Had my CP-800 for about a month now. Something strange just happened today. When I got home and grabed the remote to switch the power on, nothing happened. The remote's backlighting works when I press the buttons. The CP-800 reacts to manual inputs from its front touch screen but does not respond to...
                  22 January 2014, 21:53 Wednesday
                • Blindamood
                  RSP-1068 - Can I switch video input "on-the-fly"?
                  by Blindamood
                  Does anyone know of a way (via the remote) to switch the current video input without first going to the OSD?
                  For example, while I'm listening to SACD/DVD-Audio, I'm using the Ext mode (multi-channel analogs). I have set this--via the OSD--to show Video2 (HDTV) by default; however, I...
                  11 February 2005, 15:53 Friday
                • Joawen
                  2200 switch balanced to unbalanced?
                  by Joawen
                  Is there a way to program the remote to switch a 2200 between balanced an unbalanced mode?
                  Reason, i use another brand pre for multichannel which is connected unbalanced, (turns on fine with trigger) and the CP-500 for 2channel listening, now i turn off the 2200, crawl to the floor and...
                  28 December 2007, 15:42 Friday
                • I'mListening
                  RSP-1066 and Device Switching?
                  by I'mListening
                  Hello, I am new here and a pround new owner of a RSP-1066 and RMB-1075.
                  I have a question about the 1066 Remote's ability to change from one device to another.
                  Can I switch, say from a currently selected device like DVD to CD, WITHOUT having to access the OSD and manually...
                  23 July 2003, 01:07 Wednesday
                  RSP-1066 / RSX-1055 etc. Frequently Asked Questions (FAQ)
                  by Andrew Pratt
                  Rotel has a FAQ available here that may answer some of your questions. We've added several points of our own as well below.
                  1. How do I know what firmware is installed on my processor?
                  Answer: Simply press and hold the mute button on the remote and it will be displayd on the LCD...
                  15 April 2003, 14:08 Tuesday
