RDV1060 Problem
  • Armbender
    • 265
    RDV1060 Problem
    I have had this DVD player for almost a year with it working perfectly. No when I play DVD's it makes A LOT of spinning noises when loading the DVD. Also when it jumps through the chapters and the begining it creates a load spinning noise. Almost as if the DVD is spinning out of control on the loading tray.
    Has anybody come across this and if so what was the remedy?
    Samsung UN60C6300 | Primare SP32 | Primare A30.7 | Oppo BDP-103 | PS Audio Quintet | AppleTV | ELAC 247 Black Edition | ELAC CC 241 Black Edition | B&W DM 600 S3 | SVS PC 13 Ultra | Straight Wire Virtuoso | Harmonic Technology Pro 9's | Black Sands Power Cords
  • fordster
    • 211
    I've not had this exact problem but if it's spinning a lot it sounds like it's struggling to read the discs. Could be the transport or laser need looking at. You need to send it back to Rotel for them to look at (I presume it's still in warranty?).
    Dave
    • Armbender
      • 265
      Thanks..Ill talk to my dealer.. I believe it still has some warrenty on it
      • chinets
        • 855
        RDV 1060 has a lot of problems. I have 4 friends of mine and I that have bought the RDV 1060 at the same time, and we have all sent it back to Rotel for Major repairs with the Laser Alignment problems they have and the fact that it breaks down immediately after you achieve spinning problems as you have described.
        We all bought Marantz Dv 9600 NOW and we are all happy campers now especially that this dreaded RDV 1060 is out of our lives.
        Rotel make great Amps and Processors such as the The 1095 amp and 1098 Pre/Pro, but there DVD gear is good at first ,but breaks down very fast. We all had warranties and we all made Rotel refund us back in full through our dealer so we got the Marantz DVD player and never looked back!!
        My 2 cents,
        Cheers,
        Chinets
        • sirbogey
          • 344
          Had exactly the same problem 2 months ago. Was lucky it was still under warranty. Rotel exchanged the whole loading tray, but their answer was "they didn't find any fault with the player, but exchanged the tray as a precaution".... :E
          so just send it in...
          • Armbender
            • 265
            Going in today right after work
            • sirbogey
              • 344
              I'm not so sure you are gonna like it... I played couple of CDs this evening and a few CDs still cause a lot, I mean a lot(!) of spinning noise, but only the last couple of tracks. I initially noticed that on DVDs, towards the end of the movie. As for me, I'm gonna move away from Rotel and upgrade to another CD/DVD player. Not happy at all! :M
              • fordster
                • 211
                Mine seems to be going the same way! It's not packed in yet but sometime it refuses to play DVDs. It spins for a while and then stops. Other times it will play a disc but then if I pause or stop the film to do something else it won't resume when I come back, it just spins for a while and then stops. Sometimes it will play fine and then fail when trying to go back to the menu at the end of the film. Most of the time it works perferctly though and CDs are not a problem. It will be going back to my dealer for a repair at some point (they're closed whilst relocating at the moment).
                I'm not sure what I'd buy as a new DVD player at the moment. I used to have a Denon 2800 MkII and that was very unreliable (and the service from Denon was cr*p, at least Rotel's service is very good). I'm starting to think I should just buy a cheap (Pioneer maybe?) DVD player in the future. The only problem is that as I'm tight for space I also use it for CD replay hence why I had the Denon and now the Rotel. Maybe a Benchmark DAC on a cheapo player is the answer?
                Dave
                • sirbogey
                  • 344
                  Your problem is more drastic than mine, but what really surprises me is that Rotel serviced mine, exchanged the tray and the problem still persists. I find the noise unacceptable and distracting. I also went with Rotel DVD for the same reason, to play both CDs and DVDs at the same time. I was actually thinking of going with a Denon for the DVD player and adding a decent CD player. What was wrong with your Denon then?
                  • fordster
                    • 211
                    Very similar really in some ways but much more frequent. It was very noisy (much worse than my Rotel which I'd hardly call quiet) and would often (and I mean very often) just freeze whilst playing DVDs. In most cases the player had to be physically powered off to get it working again. Again, CDs were usually okay. It did this almost from the off but stupidly I put up with it until it got worse so couldn't get the dealer (internet arm of a large hifi chain in the south of England) to refund me. I sent it back for repair and it came back noisier and not long after started freezing again.
                    From looking on the internet and speaking to a few local dealers I found that this was quite common with Denon DVD players (although some lucky people never had any issues). I even rang Denon UK who denied all knowledge and blamed the fact it had been multiregioned (even though the MR firmware came from them!). That is why I would never buy Denon again as thier customer service stinks, they just deny all responsibility (I heard from other people that they got the same).
                    One day a disc got struck in the player and the eject just wouldn't work. I made the mistake of taking the lid off and trying to free it up myself rather than paying for a repair (I work in IT and being a bloke of course we are all handy with electronics!) and manged to get smoke to come out of it!! To make things worse I then realised I actually had 3 weeks left on the 2 year warranty, DOH!
                    Funnily enough througout all these problems with my Denon and Rotel my old Pioneer 535 has never let me down. I've also got a Pioneer DVD recorder and (so far, it's still only 8 months old) never had a problem with that.
                    Dave
                    • sirbogey
                      • 344
                      thanks for the info. Many people on this forum have a pioneer as well, I'll look into it in the future. but I think in general I'm done in overpaying on DVD players; they are out of date like every 2 years anyway. But I also think we just got little bit unlucky with our RDV-1060s...
                      • chinets
                        • 855
                        Sirbogey,
                        You are NOT unlucky with the Rotel 1060, because everyone I know that had one of these players have switched to other brands, because there 1060 went belly up and that is not chance or unlucky, just the simple fact that Rotel built a real LEMON for all of us!!! Stick to Rotel's Amps and Pre/Pros and forget there DVD players..THey just don't have the Know how on how to build a workable DVD player. That's life!!!
                        Sorry for the truth, but I got burnt too ,so I stick to Marantz now with NO Problems.
                        Good Luck and Cheers!!!
                        • sirbogey
                          progressive on RDV1060
                          by sirbogey
                          My RDV1060 came back from Rotel with an exchanged tray. When I put in a DVD or CD, it takes like 10 secs for the disc to load. This was a matter of 2-3 secs before. What have they done to it?
                          Another question: I changed the picture to watch a movie in progressive mode. When I do that,...
                          22 September 2006, 02:58 Friday
                        • mopustor
                          RDV 1093 spinning sound problem
                          by mopustor
                          Hi everybody,
                          I need your help figuring out if the spinning sound my brand new RDV-1093 is making is normal.
                          First a little background:
                          2 years ago I bought the RDV-1060. At first it was okay, perfect picture quality and no spinning sound issues. After about one...
                          23 July 2007, 15:32 Monday
                        • Marcel54
                          Need help on problem with RDV1060 and RSP1098
                          by Marcel54
                          I have my configuration since October last year and from the start I have a problem with my RDV1060 and RSP1098 that if correct all users of the SCART connection should have. If the RDV1060 is connected to my TV through the SCART connection and the DVD-player is set on SCART then the TFT on the 1098...
                          14 May 2004, 10:45 Friday
                        • Kemp
                          RDV1060 vs RCD 1072
                          by Kemp
                          Hi all,
                          Could anyone tell me the difference, if any, when playing a CD on the RDV1060 compared to the RCD1072. I was enquiring about the RCD1072 and the salesman advised me to rather go with the RDV 1060.
                          Any comments will be appreciated.
                          MK
                          22 November 2003, 01:20 Saturday
                        • fordster
                          RDV1060 DVDA Problem
                          by fordster
                          I've had my RDV1060 for a few weeks now and finally got round to buying a DVD Audio (Under Rug Swept - Alanis Morrisette). When I insert the disc the player picks up that it is a DVDA and shows 96-24MLP on the display. However, that's about all that happens beyond a bit of clicking. The timer eventually...
                          28 March 2005, 14:14 Monday
