I am in the middle of setting up my Rotel 1068, 1075 combo, but am not receiving any sound. I have my projector hokoked up through component to my projector and my Denon 1920. I have hooked up the audio through RCA leads on the front 2 channels on the 1920 into the 1068, audio input 2. The lights on the 1075 R and L speakers are not lighting up. Why am I not getting audio?
Help with connecting up my new Rotel / Denon system?
do you have RCA jacks going from your 1068 to your 1075?
is the power switch in front of the 1075 on?
also, the 12v trigger at the back should be off I think.
I would think you would want a digital connection between your Denon and 1068 ... either optical or coaxial (if you have more than 2 speakers)- Bottom
Philo,
Nice equipment - it will sound great when you get it going properly
I agree with Mike C's comments. Please also read Rotel's own helpful guide http://www.rotel.com/support/help-co...-equipment.htm as it is Rotel's own easy to use guide to set-up... From your post I suspect you need to read this several times and then post some quesitons...
Geoff- Bottom
Originally posted by PhiloThe lights on the 1075 R and L speakers are not lighting up.
:B though it would have been nice if they lit up too- Bottom
