How to add auto power-up kit to Rotel RB993
  • Belgarath99
    • 11
    I recently acquire a Rotel RB993. Unlike the new Rotel RB1080, RB1095 etc, the RB993 does not have a 12V input. I like to know if anyone has suggestions on how to go about adding some sort of auto power-up kit to the power amp to work with my Denon 3805 receiver.
    Ideally a 12V trigger solutions is best since I have a spare 12V trigger output on my Denon 3805 received but I am open to suggestions.
    Thanks for your time.
  • Clepto
    • 292
    Well, the scary option, go into the switched outlet of the receiver (;
    there are also 12v triggerable switch/plugs that can probably be found at radio shack, or the like.
    • Bluespower
      • 149
      I don't know your Denon, but precious few receivers have outlets that can handle an external power amp.
      I've built my own 12v (triggered) 110V 10A switched outlets with Radio Shack parts, but you may want to look into something like the Parasound "Scamp". I think Rotel also has a similar accessory.
      Bluespower
      • htsteve
        • 1216
        Niles Audio AC-3
        Belgarath99,
        I have the same issue with my Rotel 1095 (older model w/o 12V trigger).
        I bought a Niles Audio AC-3. It handles 1500 watts and has switched outlets that can be triggered with a 12V trigger. The only catch is that you need to snip off the the Niles Audio end of the 3.5mm wire. The leads go in one side and the ground goes in the other. Not inexpensive, but works great. :T
        I would not use any receiver's switched outlet. The 993 will be too big a load on it.
        Hope this helps.
        • DelRay
          • 369
          Another option would be to get a surge supressor/protector with 12v trigger to turn on amps w/delay. I have a MP 3500 and 3500mkll. They seem to work great with my amps.
          • Belgarath99
            • 11
            Just to be clear about this, this is a surge suppressor/protector that is connected to the mains but also have a 12V trigger to turn on and off whatever applicance is connected to it? If so, this sounds like what I want. Can you tell me what MP stands for? Is there a Radio Shacks equivalent? I live in Australia so I don't think it is easy for me to get hold of parts that are specific to America only. But we do have an electronic chain that carry Radio Shack parts so I reckon Radio Shack stuff will be my best bet.
            • Belgarath99
              • 11
              Can you kindly provide a URL to the devices you mentioned above? I have done a google search on it and the only searches that only seems to come up is a Monster Power 3500 but I am not having much luck locating specifications etc.
              • FernandoF
                • 53
                Hi, Belgarath99.
                I have just ordered this autoswitching power strip for the same purpose :
                You may want to check it.
                • DelRay
                  • 369
                  Buy.com just had a nice sale on the 3500mkll. $399 msrp. They were/are selling them for $169 w/free shipping. I believe the $50 rebate ended February 28. Still a good buy though. You can turn on the delay via 12v trigger or using a switched outlet from a receiver. Very useful.
                    I just ordered the 3500, cuz it was cheap and so am I, but this is the one I will get when my coffers are replenished.
                    Go to the APC website and take a look.
                    And yes, the rebate ended 28 Feb 06.
                    • Audio Junkie
                      RB1091 12v trigger replacement
                      by Audio Junkie
                      Hi All, my first post! I'm a long time Rotel fan
                      I have 2 RB1091 amps which I got a deal on from my local dealer several years ago. At the time he said the 12v triggers weren't working. At the time this wasn't a problem for me. However since upgrading my system late last year I now want to...
                      21 January 2021, 16:26 Thursday
                    • mike c
                      will auto signal sense ON also turn on the 12v trigger?
                      by mike c
                      say I have a parasound amp set to auto signal sense on ... will an amp connected to its 12v trigger out be turned on too?
                      29 November 2006, 03:59 Wednesday
                    • simonb68
                      Opinions please on RB993 & 1055
                      by simonb68
                      Hi folks
                      I'm interested in opinions on whether an RB993 would a good upgrade and suitable match for a 1055, with Dynaudio Contour 1.1 mains, and hopefully Contour or 122 centre speaker soon (currently an old Mordaunt Short thing, got it cheap).
                      I want to improve my 2ch...
                      21 August 2003, 09:55 Thursday
                    • JRambo
                      rsx1067 vs rsp1068/rb993/rb985mkII
                      by JRambo
                      Hi, I recently read in a home-theater magazine that the Rotel rsx1067 was their first choice in the heavy-receiver class.. How will this receiver compare to a setup with rsp1068, rb993 and rb985mkII, when it comes to sound quality, as the price for these two setups will be about the same..
                      14 June 2004, 05:14 Monday
                    • rick c
                      rotel rsx1056 + rb993 ?
                      by rick c
                      Ok, i know i've gone thru this before but i have found a rotel rb993(200 x 3) for a real good price.I'm about to get off the fence here but really need final opinions first.Will i get a significant improvement in sound quality in both HT and music by adding this amp to my setup(signature).If i wont...
                      29 December 2005, 00:12 Thursday
