Problems with analog vs digital 1068
  • jan arild
    • 7
    I have a strange problem.
    If i put in a CD (Level 42 Running in the family, track 2)
    (With this CD its very easy to hear the difference)
    At the start of the song the guitar is in the rigth channel (digital)
    When i switch to analog, and start the same song again, the guitar is in the left channel.
    I have the same problem if i do the same with my satelitt.
    The cables is connected correctly.
  • Kevin D
    • 4601
    Never seen or heard of that problem. Which one is correct?
    Kevin D.
    • jan arild
      • 7
      I just tried it in my pc.
      The guitar is in the left channel.
      • Marcel B
        • 62
        The problem may be that all you cables,both from the player and to the power amplifier(s) , are connected in the wrong way to the 1068.
        The digital connection is only a single cable, so that must be allright.
        What happens when you use the test tone of the 1068 (in surround mode, not in stereo) ?
        If the connections are correct, the tone goes in the following order: L-C-R-R surround - Center back - L surround - SW.
        With 1098 I see the names in the display, I don't know if 1068 works the same (I think it does)
        Marcel B
        • DelRay
          • 369
          Which player are you using? Do you have another cd player you could use?
          • jan arild
            • 7
            I am currently using Metz DE 81 dvd. (Same as pioneer DV 717)
            Dvd is connected with coax cable. + Analog phono cable.
            Parabol tuner with optical cable. + Analog phono cable.
            All the cables are connected correctly.
            Test tone OK.
            • Marcel B
              • 62
              Well, I have a Pioneer DVD717 and it works perfectly and has done for 6 years with 4 different amplifiers (maybe even 7 due to loaners while my Pioneer AX10 was being repaired, the reason why I switched to Rotel)
              I think the only thing left to do is loan a DVD player and connect it. If it's still switching the sides there is a problem with the Rotel (or try you DVD with another amplifier). The same problems with your satellite suggest also that the Rotel is not correct.
              Marcel B
              • Bostonears
                • Mar 2004
                • 133
                There's an easy way to test whether problem is in the DVD player or the Rotel 1068: unplug ONE of the analog interconnect cables between the DVD player and the 1068.
                For example, if you unplug the Left cable, and the sound disappears from the Left speaker, then the Rotel is doing the correct thing, and the analog output of the DVD player is the problem. If the Right channel disappears from the speakers, then the problem is in the 1068 or further downstream.
                • Kevin D
                  • 4601
                  Problem is the analog is correct! Know a way to disable one channel of the digital connection??
                  Kevin D.
                    Progressive Guitar-centered Rock Band "Fourth Estate"
                    Another post here in the Guide reminded me of a CD I have that I've enjoyed for years, but most people would never have heard of. I went to a big concert at the famous Red Rocks ampitheater in Denver, Colorado the summer of 1992 (right before my senior year of high school) that had about 6 excellent...
                    06 March 2006, 14:42 Monday
                  • Dean McManis
                    "Digital" TVs, deciphering the terms.
                    by Dean McManis
                    "Digital" is a buzzword today, and it is regularly abused. Most "digital" cable is NOT transferring high definition digital signals, but they are transferring the 480i NTSC analog signals into digital format, so that they can compress them, to get more channels across the line. So...
                    06 June 2003, 18:27 Friday
                    Digital guitar tracks by Lex
                    by Lex
                    If anyone is interested in my progress as a guitarist, I have a jam track with me playing solo on my Google Drive account. I can send to you from google drive, so I don't really send you the file, but you should be able to open and listen. It's noto perfect, but it's a huge step in the right direction....
                    11 January 2015, 21:37 Sunday
                  • fvoelling
                    RSX-1056: 7.1 analog input for Blu-Ray
                    by fvoelling
                    I've been running a 1056 with a 7.1 speaker setup for a couple of years now, and started watching Blu-Ray movies from a PS3 80GB model last year. The PS3 is connected to the 1056 with digital coax and component.
                    Since my current setup is limited to 5.1 and 6.1, both...
                    07 December 2009, 23:39 Monday
                  • Martinf
                    No true analog bypass on RSP-1066???
                    by Martinf
                    Prior to committing to a multi-channel pre-amp (RSP-1066), I’ve been studying the specifications and user manuals for both the Rotel RSP-1066 and very new RSP-1098.
                    1. Some observations from RSP-1098 manual:-
                    (a) On page 13 in the RSP-1098 manual it has an explicit...
                    19 October 2003, 07:33 Sunday
