I'm having an issue with my 1068's processing of analog inputs. My current satellite receiver only offers an analog audio output. Lately, I'm only receiving a signal through my front left channel when processing the satellite input. My optical connections work fine. Yesterday when I turned on the system and used the satellite input I received output from the left channel-- I switched to my DVD (optical input) for a few minutes and recieved output from all 5 speakers. I switched to the satellite and I received output from all 5 channels. I thought it might be the satellite receiver but I checked my VCR and noticed the same problem. It seems the processor is failing when converting the analog inputs. Any ideas?
1068 processing problem
As mark suggests, only a step further, you can just swap right for left into you're 1068 and that will tell you if its internal or external, or from there down stream.- Bottom
Yeah, I've tried those options. Today I turned the unit on and the satellite input broadcast over all 5 channels. I switched to the optical input and then switched back to my analog input and I only received output from my front left channel.- Bottom
