Low volume L/R difference on my RC-1070
  • rattmann316
    • Aug 2005
    • 24
    I noticed the other day that when I have my stereo setup at a very low volume...the left channel is considerably louder than the right. It only happens at a volume level so low you can barely hear it unless you get right up on the speakers so im not too concerned; just curious if there is a problem. As soon as I increase the volume or decrease it from this point, the left channel bias goes away. My equipment is listed in my signature.
    RB-1070
    RC-1070
    RCD-1072
    B&W-DM602 s3
  • thyname
    • 358
    Where in Northern Virginia do you live? You have same Rotel gear as me, excluding RB-1070, which I upgraded to RB-1080. Do you like your B&W speakers?
    • eelco74
      • Dec 2002
      • 394
      My rc-972 used to do that as well, but only an almost inadible level. Crank up the volume and it is gone.
      Marantz AV8802, Marantz UD8002, Rotel RB-991 and RB985mkii, Rotel RD960
      Focal/Jmlab Electra 1028S, Electra CC, Electra SW1000S, Cobalt 705
      Pioneer KRL-37V, Epson EH-TW8100, Kinkping CES-180 77"inch
      • Taito
        • 226
        Same problem, opposite side over here. I also have the RC-1070. I wouldn't worry about it.
        -Ben
        • audiofan
          • 272
          i don't have problem like this with my rc-1070 , but rarely listen to music at very low level volume.
          • rattmann316
            • Aug 2005
            • 24
            thyname,
            everythings stationed in mclean. love my speakers of course. i listened to a ton of speakers before settling on the b&ws...they have a warmth to them that i didnt really get in any other set of speakers that were in my price range.
            thank you all for your replies...i feel much better. :T
            RB-1070
            RC-1070
            RCD-1072
            B&W-DM602 s3
            • benny
              • 112
              sounds like the volume pot needs to be cleaned/replaced. i've had this problem in some Audiocontrol car equiptment and it drove me nuts. i'd get it fixed unless it truly isn't a problem for you. good luck....
              • lvhung
                • 301
                Great Rotel electronincs,
                If I were you I would buy the BW 704
                • Joey_V
                  • 436
                  It could be an inherent limitation of the volume pot being a regular attenuator. A stepped-attenuator, on the other hand, would have perfect and precise left/right channel balancing.
                  Right now, I'm debating whether I should send my preamp in to be modded with stepped attenuators.
                  Joey
