RC1070 no volume from remote??
  • gymguymass
    • 26
    I currently own the RC1070 preamp (along with the RB1080 amp) and have experienced an issue about 4-5 times in the last year that has me concerned. While attempting to operate the volume control, using the remote control, I get no response. Other functions, such as source selection, mute, and on/off, using the remote are fine. My resolutions to the problem have varied. A couple of times 2-3 minute reset (unplug from power) of the preamp have fixed it. Another time, I shut it off for the night, turned it on in the morning, and it operated flawlessly. Most recently, it came back on its own.
    I am completely stumped. I have owned it for about 3 years now. I know the remote is emitting IR as I checked the output using my cellphone camera. Has anyone heard of this?
    I also sent this to Rotel's tech support, but I am hoping that somone from this forum may have encountered this issue as well....
    Thank you.....
  • miner
    • 900
    Have you tried more batteries? Rotel should respond soon. Shawn is good about this.
    • hifiguymi
      • 1532
      It sounds like you've tried everything you should have to troubleshoot the problem. It seems like it's a software issue in the preamp. It may have to go in for service. Let us know what Rotel tech support say.
      Eric
      • mookdog99
        • 3
        Thank you.....
        I am having the EXACT SAME PROBLEM right now. Did you ever get this issue resolved???
        • soundhound
          • Mar 2004
          • 816
          Originally posted by miner
          Have you tried batteries?
          Sounds like a good suggestion miner.
          • mookdog99
            • 3
            Yes, I've tried new batteries. No luck.
            • gymguymass
              RC1070 - No volume with remote
              by gymguymass
              Had a weird thing happen last night with my RC1070 preamp. Last night, and for the 2nd time, my remote not able to control the volume of my preamp. All other functions my remote handles on the preamp, including mute, were working. Since it happened before, about 9 months ago, I figured I just needed...
              18 January 2007, 06:21 Thursday
            • ajpoe
              1068 Volume Issue
              by ajpoe
              I've had my 1068 for a few months now and all of a sudden my volume is going crazy. It keeps jumping up really high even after I take my finger off the volume button and the same going down. I know the update made the volume go a lot faster, and I am used to that change.... that's not whats happening....
              06 April 2005, 19:06 Wednesday
            • madmac
              Volume issue with Android!
              by madmac
              Hey all,
              A few weeks ago, I got a notification on my Samsung Galaxy Note for a major firmware update which I did. After the update (Using Google "Play Music"), the max volume output was drastically reduced for music. The phone and speaker phone works fine. The issue is with the...
              08 March 2014, 09:44 Saturday
            • MichiganMike
              Static Discharge and Volume on C2
              by MichiganMike
              In winter, I get an occasional spark from static when touching my audio stand or the equipment on it. This has the unexpected affect of changing the sound level on the C2, even if I do not touch it directly. If I switch inputs on the C2 with the remote the normal volume level returns. Has anyone...
              21 March 2007, 18:50 Wednesday
            • Dima
              RC-1070 issue
              by Dima
              Hello
              I'm using rc-1070 with rb-1070 and it works great but I experience one very annoying issue, when pressing vol + or - on the remote the volume control on the preamp might freeze and so the volume will not change (although when turning it manually it still works, also the other buttons...
              06 January 2008, 15:33 Sunday
