1068 problems
  • jimihx27
    1068 problems
    hello during playback of dvds if i pause fastfoward or go to the dvd menu and chose to watch previews there is no sound and the DTS logo is replaced with dolbypllx I have to turn it off and back on to get sound my dvd player is set to bitstream I have had the 1068 for only 6 weeks any help would be appreciated
  • Kevin D
    • 4601
    Hold down mute and tell us what firmware version you have.
    Kevin D.
    • jimihx27
      v1.1.7
      • Kevin D
        • 4601
        I think the problem you are having was fixed in 1.2.1:
        V1.1.9 to V1.2.1 - Fixed an intermittent problem of units locking into “Standby” mode until the rear panel power toggle was engaged. - Improved digital input sensing and format detection. This improvement fixes any problems with no audio when changing channels with some Scientific Atlanta HD digital cable boxes.
        1.2.2 is the newest version that fixes a bug with 1.2.1.
        Some people have had issues with certain DVD players before, but I never heard if 1.2.1 fixed there issues or not.. There are plenty of threads detailing how to perform the upgrade, get it up to 1.2.2 and see if you still have the problem.
        Kevin D.
        • ajpoe
          • 439
          Yes Kevin, it was fixed... at least for me. I had the same issue and the upgrade solved it.
          AJPoe - - Growing old is inevitable, growing up is optional!
          • Steve_the_Hokie
            1068 and Rotel problems
            by Steve_the_Hokie
            I bought a 1068 used that was only a month old. The original owner thought it was too difficult for some of the family members to operate, which I didn't really find to be true at all. Anyway, I had the unit sitting around the house for a month in the box while I was deciding what 5-channel amplifier...
            22 August 2005, 17:01 Monday
          • hired goon
            RSP-1068 component video problems
            by hired goon
            G'day,
            I'm having problems with the component input/output of my RSP-1068.
            I finally bought a TV that has component input. I connected my set-top box to the TV via component, and got a great image without any problems after one hour of use. Next I connected the DVD player...
            29 May 2005, 04:59 Sunday
          • hired goon
            RSP-1068 video quality problems
            by hired goon
            G'day,
            I think the video handling of my Rotel RSP-1068 pre/pro is acting up,
            I've got an old TV, which only accepts composite input, and is non-progressive. I've got a set-top box connected via composite to Video 1, a VCR connected via composite to Video 3, and a DVD connected...
            06 March 2005, 06:47 Sunday
          • hamiltong
            1068 Firmware upgrade problems
            by hamiltong
            Hi Folks,
            First attempts for firmware upgrade.. not so successful..
            I cannot get the HyperTerminal program (OS included version or Private Edition) to establish communications with the 1068.
            I've followed the instructions to the letter.. Back panel power...
            01 October 2004, 21:15 Friday
          • chachi
            Rotel RSP1068 & Pink Floyd Pulse 'high bitstream' track
            by chachi
            Bit confused maybe someone else can shed more insight ... I recently emailed Rotel Europe asking if the RSP-1068 would accept/play the 640Kbps DD 'high bitstream' audiotrack or not via optical, and they replied as follows:
            "Dolby specify that all standard DVD's with a 'Dolby Digital'...
            29 July 2006, 05:05 Saturday
