what amp etc work best & bang for your buck for cm9 & 684 b&w
  • reese
    • Oct 2012
    • 7
    ive just picked up some cm9 & a pair of 684 has any one got ideas for a pretty good amp set up etc preamps with out blowing a stupid amount of money but bang for ya buck type of thing??
    i was looking at a rotel rb1080 for the 200 watt cm9 & a bit smaller one for the 684 being 150watts but the pass lab x250,5 looks good as a big amp a bit dear if you get my price range but ive not herd any of these so ime going out to hi fi shop taking my speakers with me to plug them in to some of there best amps & work down from there to see what sound i like & hope its the cheaper one its for my work shop its about 20 x 20 metre square to fill with tilt slap concrete walls not the best environment to sort out it will be better if you gals & guys can point me in the right direction p.s one of the other caps on the b&w speaker site said perhaps a emotiva ime looking into that pressnetly aswell ime not sure if its got a 240 volt operating system thow for new zealand
    Hi reese,
    I'm a previous owner of an RB-1080 and a current owner of an Emotiva XPA-2. They are both worthy amps. The XPA-2 has a bit more power, which suits my 803Ds more. It is largely similar to the Rotel in all other respects. If loud music is your thing then I'd go for the XPA-2 as the extra headroom will make for a more relaxed listening experience.
    My preamp is a Rotel RC-1082, which must be relatively inexpensive now as it's 3 years old. It's a very acceptable preamp that gives me no reason to change. It has tone controls, which are useful if your speakers lean towards the bright side and/or you listen to a wide variety of music that might include mp3's.
    • reese
      amp & set up sugestions please for cm9 & 684 b&w to get bang for my buck
      by reese
      i was looking at a rotel rb1080 for the 200 watt cm9 & a bit smaller one for the 684 being 150watts...
      10 October 2012, 22:39 Wednesday
    • reese
      cm9 & 684 b&w set up info for amp etc i need help
      by reese
      10 October 2012, 06:07 Wednesday
    • JaonL
      B&W 684 with Rotel Ra-05
      by JaonL
      Please help me. I'm fairly new to this. I'm trying to set up a good stereo system. I would like to know if anyone has experience with the B&W 684. Is it a good all rounder for all sorts of music. Does it match with the Rotel Ra-05. I'm on the verge of purchasing the amp and speakers. Have heard...
      07 January 2008, 02:14 Monday
    • JaguarXKR
      Which has more bass? 683's vs CM9's?
      by JaguarXKR
      Which of these speakers have better bass, since i am building my system and i have two 684's right now, but want my next pair to have more bass. So which of these two have better bass, 683 or the CM9's?
      Thanks for any info,
      Mike
      14 September 2012, 17:19 Friday
    • JaguarXKR
      Is my reciever up to the test for B&W's?
      by JaguarXKR
      I currently have a Pioneer SX-1080 and a Sony STRDH520. Currently looking for Sansui G-9700. Are my two current recievers decent enough to power my B&W's 684's and most likely CM9's?
      30 September 2012, 17:10 Sunday
