I just hooked up my trigger for he first time. The C1 to A51, using the on-off trigger, works fine. I also want to use a trigger to turn on a Panamax 5400-EX power conditioner that has the rest of the equipment connected to it. Both the C1 and the Panamax use a standard 3.5 mm mini-plug (unlike the A51). Not having a trigger cable I tried a Sony 20' control cable that is used for the projector into one of the programmable triggers set to on-off. It didn't work.
Is a trigger cable a specific cable -- meaning that I have to go to Radio Shack and buy a "trigger" cable? Is there a maximum length to a trigger cable?
Secondly, I have an NHT subwoofer for the LFE channel in the front of the room. I want to add a second NHT subwoofer in the back of the room. How does one calibrate (auto or manual) the second subwoofer. The front woofer is 16 feet away from the listening position and the back woofer is three feet. When both are on how is the level set? How is the distance set?
Thanks for the help.
Craig
Craig
