Marantz 7702 Trigger issue
    • 27460
    Jon, can you explain what this means to me?
    "I did find the reason that trigger 1 is not working properly. It is not the 11.94v pulse that it initially emits but the 2.12v current that it drops to after the initial pulse. Trigger #2 (which works) has an initial pulse of 11.99v and drops to 3.95v.
    Panamax requires the lower voltage to be no lower than 3.5 which is the reason why it begins to turn on and than suddenly turns off.
    I hope this helps anyone who is experiencing trigger failure on the 7702."
    A guy at another forum said that, so I quoted it.
    Both of my triggers are not working on my Marantz 7702. First 1 quit working, then I went to number 2, then it quit working. Is he saying this is permanent, or a reset or a problem with the unit being plugged into a Panamax surge protector affecting the triggers?
    I do happen to use a Panamax surge protector wirh the round blue dials.
    Right now I have to turn my amps on manually. It's like the stone age. :B
    Thanks Jon
    • 4158
    The problem appears to be, or at least could be, with the Panamax, based on the quote. I think I would try a different source. Maybe just a regular power strip just for diagnosis to see if it is the Panamax. It would be nice if it was something simple.
      • 27460
      good idea Lee, I have an alternative power source nearby. Thanks.
