Problem with a Sub
  • spykids777
    • Dec 2010
    • 69
    Problem with a Sub
    Hi, I know this is not a JL Audio Sub section but I know that a lot of the people on this forum like me have B&W 803Di speakers with JL audio Fathom 113 Sub. I have a serious problem where the pin of my RCA cable broke off in the Lt/Mono socket on the back of my sub :M . Any suggestions on what to do? Has anyone taken off the back of the Sub before? How easy is it? I received an e-mail from the company NOT to remove the central Hex Nut - no explanation why. Any help will be appreciated!!
    Thanks.
  • jeepers
    • Mar 2010
    • 40
    Is it possible to bring the F113 to your dealer for him to take care of it ? That would be safer.
    • spykids777
      • Dec 2010
      • 69
      As you know it is a BEAST to carry. By myself I can barely drag it across the floor! If nothing I might have to get them to come to my house.
      As per the tech support reply I can use the RT input if I am using only a mono sub or use a RCA to XLR adapter and use the lt/Mono input. is anyone doing that? I just wanted to take care of this problem and not just ignore it - just trying to keep the Sub perfect with no defects
      • leej
        • Feb 2009
        • 82
        Is there any way to screw a very small screw into the pin, to pull it out? I can't immagine that the pin is lodged in very tight. If there is no opening in the pin to screw into, and you are good with tools, you could drill a small hole into the pin and then use the screw to extract the pin. If you aren't skilled at drilling such a hole, I would just use the Rt input, as it would be easy to damage the connector.
        After posting this I thought about the possibility of the dirll bit binding in the pin, causing the pin to spin and damage the connector. You might be better off having a qualified tech do the repair. (or just use the Rt input connector)
        Lee J
        Denon 4311ci; Rotel RB-1080; OPPO BDP-83 Universal Disk/Media Player
        B&W 703 mains; B&W HTM2 Center; B&W CDM SNT-Surr; B&W CDM1nt-back; Pair of Rythmik F15 Subs
        • mb225
          • Jan 2009
          • 131
          I'm not sure if RCA pins are magnetic or not, but maybe you could try to use a very strong magnet to pull the pin out?
          • spykids777
            • Dec 2010
            • 69
            Thanks for all your feedback. I am not sure a magnet will work. I talked to tech support at JL Audio - I have to say WONDERFUL support even on a weekend night. :T . Apparently the Fathom subs are Vaccum sealed and require at least 2 people with prongs on one end to break the seal and pull the sub apart. Even after that the whole thing has to be disasembled to get to the RCA jack from inside. Also the central allen wrench screw apparently turns the Torroidal transformer and it will snap if the central screw is turned. Glad I did not do it.
            Apparently even the other RCA jack can be used as a mono input also. Another thing is that the XLR inputs are also separate, so currently I am using the LT XLR input and it works great.
            • kaeo
              New to HT and problem with cable types
              by kaeo
              I just picked up a Yamaha htp-5630 and the output to my sub is in rca format. I mean it's a single plug output similar to the video cable from my dvd player. My problem is that my sub has a different style of input. I don't know what it's called but it's two cables sleeved together; one a positive and...
              21 February 2004, 16:58 Saturday
            • Snap
              Sub Placement Problem
              by Snap
              Maybe you all can offer some ideas. And I am praying that SOME ONE out there has had to put the sub behind the seating area! ops: and I hope that they can give me some feed back. Here are the facts.
              The Room that this Theater is in has NO side walls. You are looking at front and back...
              29 March 2005, 21:16 Tuesday
            • ICEMAN70
              Rotel RSX 1057 Sub Crossover Problem...
              by ICEMAN70
              Hi guy's
              I allways had my sub crossover on the Rotel RSX 1057 on 100hz. I have a large room and like little bit more bass. Recently i got a new Paradigm Servo 15 V2 to replace my old mission Sub. Anyways now i developed a Poping sound when the receiver changes settings from prologic to...
              22 August 2008, 10:52 Friday
            • mfishmike
              Looking for a Rotel 1065 tech for a sub pre-out question
              by mfishmike
              I've got the Rotel 1065 receiver/amp and it comes with two sub pre-outs. The manual tells me they are RCA 1.2v (or close), out to the subwoofer amplifier.
              The picture in my "avatar" to the left is my latest DIY subwoofer project. It has two active drivers and 4 passive radiators,...
              25 December 2005, 15:14 Sunday
            • Jerm357
              Custom RCA to 1/4 mono subwoofer cable ?
              by Jerm357
              I want to make a subwoofer cable with a RCA connector and a 1/4 mono plug. I am planning to use a old MonsterBass™ 300 Subwoofer cable and use the one of the RCA on it and cut an end off and solider a 1/4 mono plug on the other end. Now the question is what a good 1/4 mono plug that will fit on this...
              31 May 2006, 14:05 Wednesday
