New to HT and problem with cable types
  • kaeo
    I just picked up a Yamaha htp-5630 and the output to my sub is in rca format. I mean it's a single plug output similar to the video cable from my dvd player. My problem is that my sub has a different style of input. I don't know what it's called but it's two cables sleeved together; one a positive and one a negative, just like my satellites. Is there any way to make my current sub work with this type of rca output? Some type of converter maybe? Any help would be greatly appreciated. I don't want to have to buy another sub, eventhough my current one is terrible. Thanks
    kaeo
    Hi Ian, welcome to The Guide! :later:
    Some models of sub-woofers have two inputs for signal. My Velodyne FSR-15 does. If I want to run one input to it, I use the right channel connection and if I want to run two inputs (corresponding to the L/R channels) the I use both connections (and 2 cables).
    What brand/model is your sub? The owner's manual is probably available on-line and we could check compatibility that way. If you don't want to wait, well. . . . Are the RCA jacks on your sub the standard size? Or are they the smaller pin-type like you'd find on PC systems? If they are the standard size and if you are feeling lucky, you could try connecting a cable from the Yamaha to the sub and see if you get any output. Be sure the volume is turned off when you connect them, and then very slowly increase the gain. If you get no response, try the other connection. We ARE talking about a low-current signal here, not 110V. Having said all this, I recommend waiting until we can look at the specs on the sub.
    /// Enter basic disclaimer here: ///
    We aren't responsible for damage to your system's components if you try this.
    David - HTGuide flunky
    Our "Theater"
    Our DVDs on DVD Tracker
      • 27460
      It "sounds like", you've got a passive subwoofer. (not powered), and all you see is the speaker inputs. You will need an amplifier if that's the case from the pre-amp RCA to the amp, then left and right speaker outputs from the amp channel to the sub.
      Again, if we know what gear you have, we can better tell what's going on here... I'm going to go out on a limb here and say you've got a Bose Acoustimass subwoofer. Maybe....
      Lex
      • kaeo
        well I wen't out and bought a sub with an rca input, so no worries anymore...But thanks for the info about having a amp for the sub with speaker wire.
        kaeo
        thanks for your help
          That's Great! Not only a new sub to play with, it's definitely got the proper connects. Congrats on the new toy, Ian. What'dja get?
          :banana:
          Our "Theater"
            I agree, I would conclude that's a passive subwoofer. Not inherently any better or worse than a powered subwoofer, but I have noticed that comparnies tend to make subwoofers passive if they're building them on the cheap side.
            Well, congrats on the new sub! Always an easy way to solve HT problems, just buy new stuff! Another banana for you: :banana:
            Luke: "Hey, I'm not such a bad pilot myself, you know"
            • subynube
              Trigger for sub amp
              by subynube
              I have a parts express HPSA 1000 plate amp, that is triggered on through RCA inputs on the amp, when a signal is recieved from the receiver's sub RCA output. I am now using Emotiva UMC-1. I need to have the processor volume up at high volumes to get the sub amp to trigger on. If I listen to music at...
              03 March 2010, 20:06 Wednesday
            • Rolyasm
              Two subs, one output?
              by Rolyasm
              I have been using an older Polk Sub but recently came upon an Earthquake sub. I want to hook both up, but my Denon 3803 only has one Sub RCA output. Can I run my other sub off of the subs outputs? Does it matter which sub I set up first? Hope you are following this... So the Receiver...
              26 September 2005, 08:20 Monday
            • cadolfan
              Sub XRL Jacks
              by cadolfan
              Hi I tried searching for the answer to my question but I couldn't find anything.
              I recently purchased a powered bass monitor for musica live performances. I'd like to use it for home theatre use when I'm not performing. There is XLR inputs and outputs. My Harman Kardon AVR 325 uses RCA subwoofer...
              10 August 2008, 18:23 Sunday
            • mfishmike
              Looking for a Rotel 1065 tech for a sub pre-out question
              by mfishmike
              I've got the Rotel 1065 receiver/amp and it comes with two sub pre-outs. The manual tells me they are RCA 1.2v (or close), out to the subwoofer amplifier.
              The picture in my "avatar" to the left is my latest DIY subwoofer project. It has two active drivers and 4 passive radiators,...
              25 December 2005, 15:14 Sunday
            • umasgrad
              Optical inferiór to RCA ?
              by umasgrad
              Hi all,
              I thought this was so simple! optical being digital should be better than analog RCA connector!! Well, seems not to be the case... atleast for stereo listening
              My setup is
              Rotel RSX-1057
              BW 602
              REL STROM V
              Monster Optical interconnect...
              25 July 2006, 03:49 Tuesday
