Rotel RSX 1057 Sub Crossover Problem...
  • ICEMAN70
    • 139
    Hi guy's
    I allways had my sub crossover on the Rotel RSX 1057 on 100hz. I have a large room and like little bit more bass. Recently i got a new Paradigm Servo 15 V2 to replace my old mission Sub. Anyways now i developed a Poping sound when the receiver changes settings from prologic to dolby digital.
    Never had a poping sound before, and was wondering if this is normal? I am also using a Y-Adapter on the sub that i never used on the mission sub. I wonder if this have any contribution to the poping noise?
    I turned down the crossover to 80Hz but still didn't make a difference. I really can't tell the difference between 80 an 100 in my room anyways..
    So is this normal or should i have the receiver looked at?
    Note: All my speakers are hooked up to the rotel RMB 1075. I am using the 1057 as a pre/pro...
  • Kevin D
    • 4601
    Sounds like your new sub has introduced some type of ground problem on the system. Pick up a 3-2 prong adapter for where your sub plugs in and see if it makes a difference.
    Kevin D.
    • ICEMAN70
      • 139
      Kevin D.
      Thank's Kevin, Will give it a try.
      cheers,
      • Kevin D
        • 4601
        Might be a rumor, but I have heard they are illegal in Canada. Might have to get a spare power cord (if it's removeable) and break the ground pin off to test.
        Kevin D.
        • style
          • 1562
          Hi ICEMAN70,
          I have had some like problem in my old house ....
          with a switzerland possiblity 2 (+,-) or 3 (+,-,ground) with someone product
          with the ground (3) i have problem and if I go without the ground is all OK.
          try with a 2 adapter in my house with this easy solution I don't have any problem.
          Omar
          • ICEMAN70
            • 139
            Hi guy's
            It was the Y-Adapter.. I got a new Y-adapter and a shorter subwoofer cable and the problem is solved..
            Also on a side note.. What do you guy's run your sub crossovers at? 80Hz or 100Hz?
            Cheers,
            • Kevin D
              • 4601
              80hz here, mains slightly doubled up and set at 60hz.
              Kevin D.
              • artv4
                • Jun 2007
                • 277
                60hz
                • wanderso
                  • Sep 2002
                  • 39
                  It does sound like a ground issue.
