best way to connect my ASW608 subwoofer to amp
  • howardg
    • Oct 2010
    • 3
    Hello, this is my first post as a new member. I want to connect my B&W ASW608 subwoofer to my NAD C326BEE integrated amp. The sub has two line-level inputs that allow it to be directly connected to an integrated amplifier. These inputs are labeled "L" and "R". The NAD has "Sub 1" and "Sub 2" outputs. I think both are mono and there are two so two subs can be used. How do I make the connection? With a Y splitter cable? Or do I just connect the NAD's Sub 1 out to one of the sub's input jacks? Which one - left or right? The B&W sub seems to want a two-channel connection, but the NAD seems to offer two single channel connections. Or should I just wire the sub in with the speakers (B&W 686s). I'm confused! Thank you.
    HowardG
    • 4156
    Bass in those ranges is usually split evenly between channels. Either left or right shouldn't make any audible difference. I can't attest to every single recording , but subwoofers are pretty omni-directional. Nice system you have there !
    • howardg
      • Oct 2010
      • 3
      Thanks for the advice. Do you think I'll get equally good results regardless of whether I wire the subs in with the satellites or connect the sub directly to the amp?
      • htsteve
        • 1216
        howardg,
        Good question. Whichever device has the better crossover should provide better performance. My guess is that it would be the NAD. You can try both ways and see what sounds better to you.
        Also, welcome to the forum. :T
        Hope this helps.
        • howardg
          • Oct 2010
          • 3
          Thanks again for the advice and for the warm welcome.
          • Ron526
            • Oct 2006
            • 54
            A solution that I used is to get a Y connector with all male ends.
            Single RCA end into the amp then 2 RCA cables to the sub's L/R.
            I may be fooling myself, but I feel better with a L/R input to the
            sub, ASW600.
            Ron
            • ryan.devry
              • Apr 2008
              • 60
              howardg:
              I have a similar set up. Two mono outputs, B&W 685, and ASW608. I tried it in line with the speakers, a y-connection, and using both monos (one left and one right). I didn't notice much if any difference either way. It took some adjusting on the subwoofer, but that is the fun part right?
              I would recommend hooking it up either using the Y connection or using both mono outputs (one as a left and one as a right)...........I like the subwoofer controls to adjust using the RCA inputs better than the line level.....Just my opinion....Good luck!!!
              Ryan
              • chinets
                How to connect 2 Subs to an RSP-1098????
                by chinets
                How to connect 2 Subs to a RSP-1098?????
                Hi Everyone,
                I have a Rotel Processor RSP-1098 and I have just received my second Sub which are the ASW 850 and I want to connect them:...
                05 February 2006, 16:26 Sunday
              • chinets
                by chinets
                Hi Everyone,
                1) Do I connect sub 1 in The processor under Sub 1 Input and the 2nd Sub in the Sub 2 Input??
                05 February 2006, 12:04 Sunday
              • crytklmass
                multiple subs
                by crytklmass
                I have a Denon 431CI Receiver and Crown XLS 1500 amps. I also have 2 separate 1,0000w subs with plate amps.
                I am also currently building 2 12" subs which will be powered by 1 Crown Amp. How do I connect the subs together? do I wire both subs together inside the box and use 1 set of binding...
                14 August 2013, 23:08 Wednesday
              • Dutch BW
                CDM 1nt - with one sub, two subs, or upgrade speakers?
                by Dutch BW
                I now listen to the CDM 1nt on their own, sounds really good but am missing bottem end frequencies. These speakers go down to 60hz, as a reference a 805s reaches 49hz.
                Would it be wise to:
                a - Ad one good sub (for instance a asw700)
                b - Ad two subs but a bit less...
                06 March 2008, 11:15 Thursday
              • chinets
                Sub No. 2 working on off in the Sub set up of my processor WHY??
                by chinets
                Hi Everyone,
                I was playing a new DVD and found that in DTS it was Only playing my first sub I have, and was only allowing vocals and not that low frequency on my second Sub ??My Rotel 1060 plays all of my DTS DVDs and CDs correctly with both subs parallel in tone so I presumed the recording...
                29 May 2006, 16:14 Monday
