I have a Denon 431CI Receiver and Crown XLS 1500 amps. I also have 2 separate 1,0000w subs with plate amps.
I am also currently building 2 12" subs which will be powered by 1 Crown Amp. How do I connect the subs together? do I wire both subs together inside the box and use 1 set of binding posts which I then connect to my crown amp? or do I leave the subs separate and use 2 sets of binding posts?
The Denon 4311 has 2 sub inputs, input 1 and input 2. At this time I have my 15" subs connected via input 1 and 2
Then once I have the 12" subs built how do I connect them into my receiver? do I daisy chain using rca from the sub 1 input and connect 2 15" subs via input 1 and the 2 12" subs into input 2? OR
do I connect the subs to a box that in used between the subs and the receiver? ie, a dsp box or similar. I never tried to connect 4 subs so I never considered how to do it. but honestly the DIY bug is itching.. and im still a newbie but learning a ton as I go.
First step is how to build the 2 subs ie, both subs in 1 box or separate the boxes. I can leave the 2 15" subs up front and place the 2 12" behind the seat or maybe build a riser platform for placement under the couch ???
second question is how to connect all of them.
If you need more details please ask, I can be more descriptive.
