Distortion - low volume
  • Kobus
    • Aug 2005
    • 402
    I have 803's and am really enjoying them. (Under !)Powered by Pioneer AXA5i which will soon be replaced.
    Even with the Pioneers they sound very good. 125+- WPC and I have never had a problem with clipping / distortion even at moderate volume.
    Yesterday I purchased a new recording of one of my favourite CD's. Mike Oldfield, Tubular Bells 2003. On the main track, at fairly low volume there is a 5 second piece of base that my one speaker distorts. Why? Can it be a problem with the recording?, Speaker (NO), or what.
    What can I do to check this out?
    Thank you
    Kobus
  • Karma
    • 801
    HI Kobus,
    You can determine if the problem is the speaker or further up the equipment stream, including the recording, by simply reversing the speaker leads on your amplifier left for right. If the problem moves to other speaker, the problem is not your speakers and you must look elsewhere. If it remains in the same speaker it's the speaker.
    Have you noticed any problems with other recordings? In the same speaker? Good Luck.
    Sparky
    • Kobus
      • Aug 2005
      • 402
      Thank you for the advice. I have now isolated the problem to the recording.
      1. If I hear something tha sounds like distortion, can it be a problem with my CD only or will it be in the master?
      2. Can this "distortion" damage my speakers or is it only true distortion that can cause damage.
      I will go and check out another CD at the shop.
      Thank you
      Kobus
      • misterdoggy
        • 1418
        A distortion from a CD can't hurt your speakers.
        A distortion resulting from something electronic is different
        I'd bet its probably either the CD or you are hearing things in recordings that you never heard before because of the quality of the reproduction.
        • SpinMonster
          An active TMM wave guide speaker
          by SpinMonster
          I’ll start this off by saying that I will never build another system without a wave guide. If there are any downsides, I don’t see them.
          This system uses 2 RS180 midbass and one XT25tg60 (double magnet) in a wave guide crossed actively at 1700hz. The XT25/60 is superior to the single...
          16 September 2013, 10:36 Monday
        • sisu
          Solved: Tweeter distortion from my almost-finished Modula NeoD CC
          by sisu
          [Edit] The tweeter distortion problem was fixed by moving the RCA inputs to my receiver to the "CD" input, instead of the "Phono" input.
          This is my first time with DIY speaker building, and I have quite enjoyed the ride.
          After researching and talking about...
          25 July 2009, 09:57 Saturday
        • Pete B
          Sony STR-DB1080 problem - distortion
          by Pete B
          Firstly, apologies for my first post being a question.
          I recently bought a second-hand Sony STR-DB1080 receiver and am having a problem with it - basically when the amp is first switched on everything is fine but then the sound from all speakers (5.1) starts to distort...
          18 December 2005, 06:36 Sunday
        • stevek
          distortion problem
          by stevek
          hey guys i hope some one can help me with this.i have cm9 cmc2 hooked up to a onkyo tx sr605" temporarily" and a denon3312 out for repair do to these issues wich obviously wasnt the problem i have direct tv,denon 3800bdci,denon dvd2200.i use tributaries speaker cable, hdmi and interconnects.and...
          28 November 2011, 19:19 Monday
        • jericho
          Problem with ASW-855
          by jericho
          Since a few month's I have problems with one of my ASW855's.There is a sort of hum in the speaker and it already has been sended back to the technical service by my dealer in the Netherlands.I recieved it back but after some time the problem came back.It's like someone who turn's on the light in another...
          05 July 2007, 03:34 Thursday
