Problem with ASW-855
  • jericho
    • 280
    Since a few month's I have problems with one of my ASW855's.There is a sort of hum in the speaker and it already has been sended back to the technical service by my dealer in the Netherlands.I recieved it back but after some time the problem came back.It's like someone who turn's on the light in another room which gives distortion in the speaker.There is nothing wrong with my electric circuit because the second sub (also ASW-855) is connected to the same outlet.In may the electronic unit from my sub was sended back once more to the technical service and when it came back it was even worse.Switching the amps proves that there is something wrong with the electronic, and not with the speaker itself.I also noticed when I took the amp out once again, that a small corner of the electronic plate was broken where it is fixed to the second electronic unit below.I'm absolutely sure this was caused by the people who did the repair.I took contact with my dealer once again and he told me B&W was going to change the complete amp of the speaker.I was happy with the exchange until yesterday when I got a phone call telling me that they are once again doing a modification on the print.It seems that B&W had some problems with the first series of ASW855 and they now have a solution.It's now already a couple of months that this unit is out.I'm not very pleased with it and I think B&W could do some effort to change the complete speaker, it's still under warranty.I already drove 4 times to the dealer which is almost 600 miles to solve this problem.
    I saw on the amplifier unit inside a small paper with the notice "ASW850"
    I'm wondering if there are others here on the forum with the same sort of problem??
    Is it normal "ASW850" inside the ASW855???
    Maybe Aldo do you have some experience with this sort of problem???
    What would you guys do???
  • miner
    • 900
    I do believe the 850 & 855 use the same amplifier. B7W will take care of you - let your dealer fight the battle for you.
    • Aldo
      • 448
      I once had the same problem with another sub brand and it was a loose silver soldering of the amp, it seems that with the high vibrations that the sub produce with time, some times happends and in my case that was what produce the hum.
      I also had that problem with my ASWs but it always had something to do with the electric supply, "bad ground instalation".
      • jericho
        • 280
        Thanks for your reply Aldo but I'm sure it's not a grounding problem!
        • hifiguymi
          • 1532
          miner is right in that the ASW850 and ASW855 use the same amp. The only differnce is the driver itself. The enclosure is the same as well.
          It does sound like a bad solder joint or ground in the amp itself. Contact your dealer and B&W directly and they will take care of it for you in sure.
          Best of luck.
          Eric
          • jericho
            • 280
            Best of luck.
            Eric
            My dealer already sended the unit two times back to B&W Netherlands, and still the same problem!!!
            • Gremal
              • Apr 2007
              • 195
              Well, there is the key difference of the paper/kevlar vs rohacell/kevlar cone.
              Integrated 7.1 HT and Two-Channel System
              Pioneer KRP-600M | VAC Phi Beta 110i | to be determined front end
              B&W 802D | B&W HTM1D | B&W ASW-825 | B&W N805 | B&W SCM1
              VPI Scout | Oppo BDP-95 | Tivo Series 3 | Integra DTC-9.8
              Audio Refinement Multi-5 | PS Audio Premier | Goertz and Electra Glide cables
              • nick.h
                • 171
                Which is better?
                • nick.h
                  Subwoofer - ASW850 VS ASW855 VS Velodyne DD18
                  by nick.h
                  I'm in the market for a subwoofer and looking at,
                  1. ASW850 $2,500 (S/hand)
                  2. Velodyne DD18 $4,500 (S/hand)
                  3. ASW855 $5,200 (New)
                  The ASW850 is the cheapest option, is there much difference between that and the ASW855? Any owners of both...
                  30 October 2007, 16:44 Tuesday
                • wildmda
                  Diagnose and Repair ASW855 Subwoofer
                  by wildmda
                  I have an ASW855 Subwoofer. It does not turn on. I checked the fuses and they seem to test fine. Can someone help me please:
                  1). diagnosing the problem?
                  2). tell me where I can find parts for this subwoofer?
                  B&W no longer sells parts for the subwoofer. ...
                  11 January 2019, 23:13 Friday
                • Birdy
                  Possible issue with Classé?
                  by Birdy
                  Need some help from the experts.
                  My system is 202-700-2200-802D
                  Due to my living place I’m quite restricted in the way I can position my system.
                  So speakers are 3.60m from each other, listening position is about the same distance.
                  There is chimney, 80 cm deep, between...
                  14 November 2007, 14:58 Wednesday
                • Aussie Geoff
                  ASW855 Appears...
                  by Aussie Geoff
                  Dealers (inlcuding mine) have started to recieve shipments of the ASW855 sub and B&Ws web-site has been updated to delete the previously announced ASW865 and ASW875 subs... Interesting - as spec-wise the ASW855 seems awefully like the proposed ASW865...
                  Perhaps
                  23 July 2005, 20:38 Saturday
                • nick.h
                  ASW855 - Damaged
                  by nick.h
                  My ASW855 subwoofer has been damaged while moving.
                  The amplifier section is not powering up, does the ASW855 have a crossover aswell as a amplifier or is it all in one?
                  Cheers
                  Nick
                  19 February 2007, 16:00 Monday
