Comp causes OTA reception issues??
    • 3815
    So I am messing around with my second computer, which is currently sitting about 3 ft away from my DLP TV, and about 4-5 ft away from my terk HDTV antenna. I'm sitting here watching football while working on the PC, and noticed that my reception was really getting bad, to the point that I no longer got a picture at all. I then realized that upon turning off the PC, the reception instantly came back, perfect HD and everything... granted I do have the actual PC open while I'm working on it, so I wonder if there is really that much EMI coming out of the comp? Or if it is simply a matter of power or something (although the PC is plugged into a different outlet than the TV and antenna). Anyone else seen anything like this?
    -Chuck
  • madmac
    • Aug 2010
    • 3122
    Well, If turning off the computer solves the bad reception issue, then you have found the cause for sure!. The computer is either affecting the TV or the HDTV antenna or both for that matter. You could try plugging the computer into a different receptacle and see if that helps?. Worse case, you'll have to move the computer away from the TV.
    Dan Madden :T
    • JeremyG
      • Sep 2008
      • 481
      Huh, pretty weird Chuck. Do you have a power supply or something that's not grounded? Did you check a bunch of TV channels to see if they all had problems? We use a big OTA antenna in the attic, and when certain appliances kick on they momentarily scramble TV reception on all channels. Could be EMI, could be on the electrical lines. But that is only for a second or two. I'm interested to hear what you find out.
        • 3815
        I confirmed it does affect all channels. It's an indefinite effect, as in it keeps interrupting the channel until I shut the PC off. Also to clarify, the devices are all plugged into the same circuit. My curiosity is whether it's an EMI issue or power. If it's EMI then maybe it'd be possible to build a pseudo faraday cage around the inside of the PC case or something.
        This is almost perfect timing though as our payload at work is going in for EMI testing so maybe I can quiz the guys there.
        -Chuck
        • JeremyG
          • Sep 2008
          • 481
          We have a dedicated group that works EMI. Usually when we find a problem and it's not a component defect they'll either install a power filter in line with the offending unit, or add a ground. Sounds to me like you have a ground issue or a bad power supply. Why don't you try wrapping it with aluminum foil and see if it helps? Sounds funny, but it could. Just don't overheat anything.
          • JeremyG
            • Sep 2008
            • 481
            You might also have something shorted together acting like an antenna, thus amplifying the effects.
            I hate these kind of things. I had a problem in my living room earlier this year where whenever I was listening to the HT, and turned the overhead fan light on, the left and right mains would pop. It ended up being that the power supply in the fan would cause the issue only if the fan motor was on while I turned the light kit on. The light kit by itself wouldn't cause the issue. Since I couldn't change the fan out (well, the wife said no) I tracked the other side of the issue to a cheap pair of RCA's what went from my AVR to my UPA-2. I built a new set of cables with good connectors and coax, and no more problem.
            • madmac
              • Aug 2010
              • 3122
              Just an FYI about OTA DTV reception. DTV over the air is vastly better than the old analog broadcasts. They travel farther and of course, produce a stunning, widescreen 1080i picture with dolby digital sound thrown in for good measure!.
              They can be finicky though!. Stuff like the computer mentioned above, airplanes flying overhead, bad weather etc. can reek havoc on the DTV signal causing blackouts or not getting the reception you had yesterday no problem at all the next day!. I wanted to watch golf yesterday afternoon but my NBC signal was too dodgy and there were too many blackouts so I just walked away. DTV is either on, or it's off. Unlike the analog signals where you would get 'snow' if the signal was not great, Your TV picture and sound will simply shut off if the signal is compromised.......some days, it's just gone altogether, probably due to some weather disruptions somewhere between your antenna, and the broadcast one.
              All that being said though, 99% of the time I get a crystal clear picture and sound no problem. I have a small outdoor antenna with a rotor incorporated to fine tune the signal if needed. Remember one thing, the bigger the antenna, the better DTV signal you'll get with fewer blackouts. Another thing is the location of the antenna. That is paramount to good DTV playback. Even the movement of a few inches can make a huge difference in the consistency of the signal. Remember, free is as free does so what your getting for free here is absolutely fabulous compared to what used to be!!.
              Dan Madden :T
              • Kevin P
                • 10812
                Have you tried putting the cover on the PC? The cover does work to keep RFI/EMI from escaping from the PC innards and interfering with things like OTA TV reception. That's why plastic cases have a metal shield on the cover. Also check to make sure the case is grounded.
                  • 3815
                  Yes I did actually close the PC case once I was done piddling with it, and the signal improved but was still horrible. I think Jeremy could be right in that it might be the PC's power supply, as it has been acting up. I moved it to another room altogether for now, just thought it was pretty crazy how it was night and day. PC on, boom, OTA signal 100% gone, PC off, OTA signal 100% crystal clear. I'll have to keep playing with it. Might start building PCs with little faraday cage like liners or something (new snake oil business? anyone? :P)
                  -Chuck
                  • JeremyG
                    • Sep 2008
                    • 481
                    I talked to one of our EMI guys today. He seconded the power supply.
                      • 3815
                      Hmm I might actually pull the PS out of the case and run it standalone to test that theory. That is one part I have had horrible luck with in computers over the years. Didn't matter whether I bought a top of the line PS or a POS PS (heh). Almost always the first component to fail for me.
                      -Chuck
                        • 16128
                        Well PSU's are one of the most stressed components generally. I've never had much issue with a decent quality unit. Generally I always buy something in the gold certified area.
                        • stainless
                          directv hd box used for OTA HD only?
                          by stainless
                          Im looking to buy a small HDTV for a bedroom and I wont be running cable or sat. to it, just antenna. Im looking at a low end TV and the only reason it peaks my interest is the cost and the built in HD tuner. I do have an HD directv box not being used so I was wondering if that box can be used as a...
                          03 February 2008, 12:12 Sunday
                        • alstein
                          Toshiba 57HX93 and Antenna connection
                          by alstein
                          HI
                          I purchased a Radioshack UHF/VHF HDTV #15-1880 antenna, and initially connected it to the antenna 2 (input #7) of my Toshiba 57HX93 TV. When I went to setup to configure this input, no channels were found. have been unable to find anything at all in the Toshiba manual about this tuner and...
                          25 April 2004, 08:30 Sunday
                        • DavidY
                          Need advice to improve antenna reception
                          by DavidY
                          Today, I just upgraded from a 19 inch TV to a 32 inch JVC AV32D201. The reception on the 32 inch is much worse, unwatchable really, than the 19 inch. Is there anyway to improve the reception without buying an external antenna?
                          BTW, I am using rabbit ears with the 19 inch TV (now located...
                          18 October 2000, 21:43 Wednesday
                        • J.H.
                          Sirius Radio In House Reception?
                          by J.H.
                          I know off topic for this forum but I am my wits end. I have had Sirius radio in my truck for a few weeks now. I have the sportster sirius radio in my truck and have no problem with reception. I just bought the Sirius sportster SP-B1 boombox and connot get reception at all really. I moved the satellite...
                          19 December 2005, 16:54 Monday
                        • ssv
                          Direct TV dish as HD OTA antenna?
                          by ssv
                          I JUST got my 42" plasma flat panel HD tv (Magnavox 42FM230A), mounted on the wall, looks great with DVDs. According to Antennaweb.org I'm about 21 miles from my local HD stations transmitters. The previous owners of this house had a DirectTV dish and LEFT it mounted on...
                          25 March 2006, 17:43 Saturday
