Toshiba 57HX93 and Antenna connection
  • alstein
    • Apr 2004
    HI
    I purchased a Radioshack UHF/VHF HDTV #15-1880 antenna, and initially connected it to the antenna 2 (input #7) of my Toshiba 57HX93 TV. When I went to setup to configure this input, no channels were found. have been unable to find anything at all in the Toshiba manual about this tuner and which inputs it works with, but I did, in fact, switch to antenna 1 just in case, with the same results. I did get some reception on lower number channels (2, 6 and a couple of others) with the antenna gain switch turned off. Manually connecting to different chaannels only results in snow without a hint of a picture. Another forum has had several messages about off air reception of HDTV channels in Montreal (where I live). Since the 57HX93 comes equipped with an "8VSB/QAM Tuner for receiving terrestrial and digital cable-in-the-clear signals.", I assumed that connecting the antenna to one of the antenna inputs would result in something. Any suggestions would be appreciated.
    Twin Moderator Emeritus
    • 16706
    Well I don't know about the quality of the Rat Shack antenna's but I've heard good things about Terk Technologies. Here's a link directly to their HDTV models: HDTV Outdoor Antennas. I would suspect that like with most electronics, the quality of product you buy is directly in proportion to the quality of signal it will produce. Now I'm far from an antenna expert but I'll do my best with some helpful info.
    Now depending on if you live in a suburb, rural or metropolitan area and if you're close or far away from the broadcast tower you may require a different antenna for your home. You will also need to find out which direction to aim it. Obviously knowing where the broadcasters are will help but you'll likely need another person to tell you, when you're up slowly adjusting it, when the signal becomes clear. You may also want to email Toshiba and find out exactly how their TV's work with OTA HDTV. I might also try contacting Terk, or another quality antenna manufacturer, and find out what recommendations they have.
    Hope I was some help, let us know if you need anymore
    • alstein
      • Apr 2004
      Thanks for your help.
      Aron
      • Trevor Schell
        Toshiba 57HX93 The Story, The Results!!
        by Trevor Schell
        Hi!
        I just purchased the Toshiba 57HX93 last weekend and have it installed into our family room. High Defination broadcasts are aquired courtesy of the Bell ExpressVu 6000 HD Satelite Receiver.
        We had made some changes in the house in which the downstairs Theater room was converted...
        05 April 2004, 15:28 Monday
        Amplified TV antenna?
        by Hdale85
        I live in the city and there are lots of tall building around so aparently I need an amplified antenna for my HD TV tuner card. I have a terk non amplified and can't get a good signal at all. My question is does anyone here have any experience with any amplified antenna's that you would recommend?
        25 January 2008, 21:53 Friday
      • Paul51
        HDTV Antenna's
        by Paul51
        I don't know if this is the right site for my question so here goes. I have DLP HDT and would like to recieve local broardcasts using an outdoor antenna. I guess someone can tell me what antenna's work the best and what antenna's to stay away from. I have a samsung HDTV with interinal monitor to recieve...
        28 October 2006, 10:36 Saturday
        Samsung SIR-TS160 HDTV Satellite and Terrestrial tuner
        by Lex
        What'a an HDTV without one of these?
        I've wanted to taste HDTV for a long time. But I quitely sat on the side line, because I had an RPTV I paid quite a lot for, that just happened to be bought just before HD came out. (lucky me) Had I done the prudent thing, I would have...
        15 September 2003, 22:09 Monday
      • madmac
        Antenna/ Signal issue!
        by madmac
        Hey all,
        Last week I watched golf on TV as I always like to do. I get my TV signals (DTV) over the air using an antenna I have situated on my roof. Well, upon turning the TV on, I get an excellent HDTV signal with no problems. At around an hour and a half in, the signal pooped out and...
        25 August 2014, 06:26 Monday
